20 Most Recent Android 7 inch Tablet Questions & Answers
My android tablet doesnt not working, power on,
master reset once if the problem persists update os
1/14/2020 3:18:28 AM • Android 7 inch... • Answered on Jan 14, 2020
My Android tablet charger broke. Can I use my
Check the voltage of both equipments, if its the same you can use it.
1/14/2020 3:18:01 AM • Android 7 inch... • Answered on Jan 14, 2020
Android tablet won't load
http://www.pandawillforum.com/showthread.php?15703-Universal-WM8650-Uberoid-v12-1-(CUSTOM-ROM)
1/14/2020 3:10:33 AM • Android 7 inch... • Answered on Jan 14, 2020
How can i unlock my andriod phone with several
You'll need to do a factory reset: 1. With the device off, press and hold Volume Up and Power. 2. Release the Power button when you see the logo, but continue to hold Volume Up until the recovery screen appears. 3. Use the Volume buttons to navigate the menu and select wipe data / factory reset. Press Home to choose the selection. 4. Press Volume Up continue. This will reset you device to factory settings, however anything on your SD card will still remain. At this point you will need to start fresh as if you just bought the device -- register with your email address, etc.
2/14/2018 7:15:43 AM • Android 7 inch... • Answered on Feb 14, 2018
Google Android 4.0 tablet will not turn on. At first it would turn on and then shut off, now it just wont turn on at all. Is there anything I can do? I just bought it off ebay for my daughters 9th b
Ounds like a battery problem,connect to mains and see if it will turn on ,if it does you will need a new battery.
1/20/2018 7:27:17 AM • Android 7 inch... • Answered on Jan 20, 2018
How to reset a factory fasttouch 7inch tablet
Hard reset or factory wipe is a method of formatting any Android device ( tablet or mobile). By doing hard reset all the apps and files that are installed or created by the user will deleted. Even the memory card will get formatted. So before going for hard reset or factory swipe, it is suggested to remove the memory card if you do not want data to be erased For simple factory reset the process is follows: Sponsored
  • Goto settings -> Back & reset -> factory data reset
After factory reset, only pre installed apps and files that came with the device will remain on it.
10/28/2017 5:34:06 AM • Android 7 inch... • Answered on Oct 28, 2017
2answers
Pattern unlock code
it will show an option forgot pattern try pressing that button and then follow the procedures
3/29/2017 2:55:41 PM • Android 7 inch... • Answered on Mar 29, 2017
Android open lock
try this program chines tablet software
12/5/2015 10:27:14 PM • Android 7 inch... • Answered on Dec 05, 2015
Factory reset freelander tablet
12/5/2015 9:52:57 PM • Android 7 inch... • Answered on Dec 05, 2015
7 inch tablet won't take a charge
change your charging connector
12/5/2015 9:49:26 PM • Android 7 inch... • Answered on Dec 05, 2015
Error message on dragon touch
format it by chines tablet software
12/5/2015 9:47:07 PM • Android 7 inch... • Answered on Dec 05, 2015
How can I get touch screen to respond after unlocking it
flash your tablet http://hines-tablet.blogspot.com/ if not change your touch screen
12/5/2015 9:40:29 PM • Android 7 inch... • Answered on Dec 05, 2015
How do I unlock the tablet when its freezing and want go the way of the password
What's the name of your tablet? and its model number?
11/20/2015 6:49:42 PM • Android 7 inch... • Answered on Nov 20, 2015
I can't log onn with WiFi. Even though I give password, it keeps authenticating- no connection. I had my computer guy look at it, too.
Hi , what device are you trying to logon with? What make model computer / router....which OS are you running? Are there any other devices on your network already cpmmected to the web?
6/25/2015 5:25:55 PM • Android 7 inch... • Answered on Jun 25, 2015
3answers
I have tried.what do i do if it still doesnt work?
If you have tried everything to get your tablet to work ans it doesn't, then time to send it to the manufacturers repair facility.
3/30/2015 6:26:49 AM • Android 7 inch... • Answered on Mar 30, 2015
I have an anriod tablet and my game dont load more thann22% how can i fix the issue?
uninstall and reinstall
3/29/2015 4:18:35 PM • Android 7 inch... • Answered on Mar 29, 2015
Android 7 inch Tablet Logo
107 questions posted
Top Android Tablets & eReaders Experts
Alison Lofts
Alison Lofts
August Brown
August Brown
Antonios
Antonios
Are you an Android Tablet and eReader Expert? Answer questions, earn points and help others
View Most Popular
  • Android Tablets & eReaders
Most Popular Question
sort out android tablet reset itelf
  • Tablets & eReaders
