20 Most Recent IBM ThinkPad T30 2366 Notebook Questions & Answers
2answers
Dvd drive wont work??? or wont play?
The decoding program was apparently lost during the restore. Follow the link bellow, it will take you to the decoding software download at IBM's support site. This should correct your problem, if not let me know.
http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=MIGR-42309
3/10/2020 5:49:45 AM • IBM ThinkPad T30... • Answered on Mar 10, 2020
2answers
Trouble resetting error code on my t-30,error code reads 0176
Error code 0176 concerned with System Security. The system has been tampered with.
Try to enter the bios setup. Save the bios setting and exit. Lets see if it resolves your problem
8/2/2019 12:03:02 PM • IBM ThinkPad T30... • Answered on Aug 02, 2019
8answers
Ibm t30 post beep error 1 3 3 1
T30's do have a well reported problem with their memory slots. It is possible to fix it if you are brave and moderatly competent with a low-power (15-20W) soldering iron with a good bit (I recommend a flat oblique tip of about 2-3mm, not a pointed one).
Firstly, heat the soldering iron and clean all traces of solder from the bit. You can use a wet solder sponge, or even damp kitchen paper. It is VITAL to remove all solder.
Remove power and battery from the T30. Open the memory cover, and remove all memory.
Taking great care, press the bit of the hot iron with moderate pressure (about twice what you would use to press a key with one finger) on each pin in turn for about 1 second, on the contacts of the memory slot that is not working. Because you have no solder on the tip, it does not matter that you touch more than one contact at a time, but there are very small surface mount capacitors between the sockets. Be careful not to touch and unsolder these.
There is a warning here. Do no wipe the iron across the contacts. Always lift the iron before pressing it on the next pin(s). If you do wipe iron across the contacts, you WILL bend and short them. These are surface mount components, and the wire contacts are easily disturbed and shorted. If you do short the contacts, it will be difficult or impossible to fix.
Remember there are pins on both sides of the memory socket. Do not worry if some of the plastic of the socket melts, it is not a problem.
Continue until you have worked on all of the pins. Patience is a virtue here. Allow to cool, re-assemble and test.
I cannot promise that this will fix your T30, but I have extended the life of 2 out of 3 T30s I worked on in this way. Note extended, because the design flaw will cause the problem again sometime in the future. The board appears to flex, which puts strain on the solder joints.
1/1/2019 8:46:16 PM • IBM ThinkPad T30... • Answered on Jan 01, 2019
3answers
Can you help me to speed my internet access and my
Internet speed is dependent on the provider. If you have DSL and there are several people or computers using the Internet, it will be slow.
Your HP610 has enough processing power and LAN speed to get online fast.
If you have had this laptop two days, was it always slow? Or did it become slow?
If it became slow, go to Malwarebytes.org and scan your laptop for malware. If you do not have a malware prevention program on the laptop, it will get trojans which will slow it down to a crawl.
You can see the various products to prevent this here.
4/7/2016 7:09:04 PM • IBM ThinkPad T30... • Answered on Apr 07, 2016
Removed my CMOS battery, but the BIOS settings won't disable
There are 2 ways you can reset your bios.
1. On the motherboard there is a small watch battery. Remove this battery along with the power cable from the power supply. Hold down the power button to fully discharge the system. Wait 2-3 minutes then reinstall the battery and plug in your system. Your reset is now complete
2. Some motherboards have a 3 pin jumper by the battery. Lets say that the jumper is on pins 2 and 3. Remove the jumper while the machine is OFF and place onto pins 1 and 2. Power on your machine for a minute. (Note: Your system will not POST). Shutdown your machine and put the jumper back to pins 2 and
3. Your reset is now complete
There might also be an option within the BIOS to "Load Defaults" if that is all you are looking to do
please see this http://www.11a.nu/software/bios-pc-bios-security-and-maintanance-toolkit/
hope it helps!
11/4/2015 5:11:15 AM • IBM ThinkPad T30... • Answered on Nov 04, 2015
2answers
Upgrading processer in thinkpad t30
I have IBM T30 laptop and my Laptop having problem of display its shows when open any files its open like viberation
7/13/2015 1:30:09 AM • IBM ThinkPad T30... • Answered on Jul 13, 2015
Recovery partition - repair
You have obviously deleted the partition that the laptop could recover from but usually if you are supplied a cd to recover windows, there is normally a drivers folder within the cd but not the aplications, such as anti virus although these are only for a trial period. for things like microsoft works if supplied, are normally on a seperate cd. Without knowledge of your partition software, you should be able to partition the HDD and then copy the files from one drive to another, but the restore may not work as the system files may not weave together when you come to restore. I would imagine it's only the drivers that's youre main concern, which you can install from your other laptop.
8/17/2014 8:37:24 PM • IBM ThinkPad T30... • Answered on Aug 17, 2014
0answers
0answers
Ibm think pad bios locked
Short pins on the bios chip. I have done this on T42's. I assume it will work on T30's as well. You'll have to search the internet for which pins to short (usually pins 5 & 6 or pins 7 & 8), but you short the pins together and turn the machine on. Be careful! Do it at your own risk. Once you are into the BIOS, you cancel the password settings and save.
4/29/2014 10:28:00 AM • IBM ThinkPad T30... • Answered on Apr 29, 2014
0answers
Wireless thinkpad t30
Need a little more info to be helpful. Did the computer ever connect to the network? If so what was changed?
3/3/2014 3:30:06 AM • IBM ThinkPad T30... • Answered on Mar 03, 2014
IBM ThinkPad T30 2366 Notebook Logo
837 questions posted
Top IBM Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
ThinkPad IBM
  • ThinkPad IBM
Most Popular Question
get ibm t30 laptop boot up all
  • Computers & Internet
