20 Most Recent
IBM ThinkPad i1200 1161 Notebook Questions & Answers
I have an IBM Thinkpad
I think cpu changing is not wise in budgetry if really you need to make your device faster .
if really you want to make it faster just change the motherboard and cpu to gether but still its not resionable.
better to try and increese the ram and the use faster hard drive .
and run only the programs only required by disabling application on startup.
What causes a blue screen
Blue screen occurs when the video port inside of your motherboard is not distributing its circuitry to the system. In laymans term, if the programs/ applications are not responding properly to its application for a very long period of time, the screen would turn blue..
Laptop resets date & time every time it starts
You have a small battery inside the laptop on the motherboard (Looks like a watch battery) that has expired. If you replace this battery your problem will disappear.
Your bigger problem is getting to this battery. Usually you can "lift up" the keyboard and get to items like the memory, etc. Check around these areas and see if you can find and replace this battery. Should solve your problem.
My Laptop Won't Continue Booting
i have had this problem i would say its your hard drive telling you im dying, i cured my prob got a new hard drive well second hand one naughty naughty.but everything ok now,you might find that if you formatted your main drive then tried to load windows,it wouldnt. ok!
Cant get ibm i series to power up when pluged in and i need to
This link below will give you laptop troubleshooting steps you can follow both hardware and software wise.
With regard to your issue, there is a possibility that either the operating system was not completely installed or a component inside the machine is damaged or needs repair.
Laptop Repair 101goodluck, hope this helps, if you have other questions just let me know
