20 Most Recent Option iCON 505 HSUPA/HSDPA USB Modem Questions & Answers
My ecco tv cant sign in Netflix and its showing massage update required but doesnt have option to update
This message indicates that your browser, operating system, or device needs an update or may no longer be supported by Netflix. Your path to recovery may take in two directions. You try updating each of the aforementioned three areas and if that fails, you contact Netflix support. There is no way to predetermine which of the three areas is the problem. If you're using the Netflix app directly on your TV, it might need an update. Here's how to do it: From the taskbar or Start menu, open the Microsoft Store. Click More > Downloads and Updates. Locate Netflix and click Download to update the app. Once the update is complete, try accessing Netflix again. Even pointing out that not all browsers support Netflix doesn't mean that is the problem. The following browsers and versions support Netflix:
  • Safari(version 11 or later) forUltra HD (2160p)streaming.
  • Chrome(version 106 or later) forFull HD (1080p)streaming.
  • Edge(version 118 or later) forHD (720p)streaming.
  • Firefox(version 111 or later) forHD (720p)streaming.
  • Opera(version 92 or later) forHD (720p)streaming.
4/7/2024 11:16:14 AM • Option Computers... • Answered on Apr 07, 2024
Mortara Eli-250 Factory Reset?
6/16/2023 6:18:27 PM • Option Computers... • Answered on Jun 16, 2023
NOOK BNTV250 keypad won't change to number pad
It sounds like there may be an issue with the touchscreen on your mom's NOOK Tablet. Here are a few things you can try to fix the issue:
  1. Clean the screen: Sometimes, dirt, dust, or smudges on the screen can interfere with the touchscreen's responsiveness. You can try wiping the screen with a soft, dry cloth or a microfiber cloth to remove any dirt or smudges.
  2. Restart the device: Try restarting the NOOK Tablet by holding down the power button and then tapping "Restart." This may help reset the touchscreen and fix any temporary glitches.
  3. Perform a factory reset: If cleaning the screen and restarting the device does not work, you can try performing a factory reset. Note that this will erase all data and settings on the device, so make sure to back up any important data before proceeding. To perform a factory reset, go to Settings > Device Info > Factory Reset.
  4. Contact customer support: If the above steps do not work, it may be a hardware issue with the touchscreen. In that case, it's best to contact the NOOK Tablet's customer support for further assistance. They may be able to help diagnose the issue or offer repair options if necessary.
4/22/2023 10:04:46 AM • Option Computers... • Answered on Apr 22, 2023
Can mastertech 50inch uhd 4k android smart tv install outside apps?
Hi, If it's android, it should be able to but you have to enable to developer mode. Please search "smart tv install third party apps" on youtube in order to find an appropriate tutorial. Thank you.
2/26/2023 3:40:23 AM • Option Computers... • Answered on Feb 26, 2023
Night Owl DVR-HDA10P82-RS factory reset ?
To perform a factory reset on the Night Owl DVR-HDA10P82-RS, follow these steps:
  1. Turn off the DVR.
  2. Locate the reset button, which is usually a small button located inside the DVR or on the back panel.
  3. Press and hold the reset button.
  4. While holding the reset button, turn on the DVR.
  5. Continue holding the reset button for approximately 15 seconds, or until the front panel LEDs begin to flash.
  6. Release the reset button.
  7. Wait for the DVR to restart and initialize, which may take several minutes.
After the reset, all settings will be restored to their default values, and all recordings and other data will be lost. Be sure to back up any important information before performing a factory reset.
2/24/2023 2:39:15 PM • Option Computers... • Answered on Feb 24, 2023
My smart tv - UN46ES7100F - won't find any wireless network. The Mac has fail. And the Service menu only shows SVC option
There are a few things that you can try in order to troubleshoot the issue with your UN46ES7100F TV not finding your wireless network.1. Verify if your wireless network is functional. To do this, try connecting another device to the wireless network and see if that can detect the network.2. Unplug your router and plug it back in after 30 seconds. This will often reset the connection and allow the TV to pick it up again.3. Check to make sure that your router is setup to broadcast the wireless signal. Some routers are setup to only allow certain devices to connect to the network by using MAC address filtering.4. Check if your TV is in Airplane Mode. To do this, press the Home button and go to Settings > General > Network > Set up Wireless Network and see if the Airplane Mode box is checked. If it is, then uncheck it and try connecting to the network again.5. Try resetting the Network Settings on your TV. To do this, press the Home button and go to Settings > General > Network > Reset Network Settings. Follow the on-screen instructions to reset the network settings on your TV.6. Consider connecting your TV to the network via an Ethernet cable. This will usually solve any connection issues since it won't rely on wireless signal.
1/29/2023 7:26:01 AM • Option Computers... • Answered on Jan 29, 2023
I don't have roma keyboard option in my anu script
Il est possible que le gestionnaire de scripts ANU pour Windows 7 ne prenne pas en charge la disposition de clavier Roma. Il existe cependant quelques solutions que vous pourriez envisager pour r?soudre ce probl?me :
  1. Utilisez un autre gestionnaire de scripts qui prend en charge la disposition de clavier Roma : Il existe de nombreux autres gestionnaires de scripts qui prennent en charge la disposition de clavier Roma. Vous pouvez effectuer une recherche en ligne pour trouver un gestionnaire de scripts qui convient ? vos besoins et qui prend en charge la disposition de clavier Roma.
  2. Utilisez un logiciel de saisie de langue rom : il existe des logiciels de saisie de langue rom qui peuvent ?tre utilis?s avec n'importe quel gestionnaire de scripts ou application. Vous pouvez effectuer une recherche en ligne pour trouver un logiciel de saisie de langue rom qui convient ? vos besoins.
  3. Utilisez un clavier virtuel Roma : il existe des claviers virtuels Roma qui peuvent ?tre utilis?s avec n'importe quel gestionnaire de scripts ou application. Vous pouvez effectuer une recherche en ligne pour trouver un clavier virtuel Roma qui convient ? vos besoins.
Il est important de noter que ces solutions peuvent varier en termes de fonctionnalit?s et de compatibilit? avec votre syst?me d'exploitation et votre gestionnaire de scripts. Il est donc recommand? de v?rifier les sp?cifications et les avis des utilisateurs avant de t?l?charger ou d'acheter un logiciel ou un outil pour r?soudre ce probl?me.
1/22/2023 10:49:55 AM • Option Computers... • Answered on Jan 22, 2023
Why is the avatar male and how do I change it please?
Unfortunately you give no clue what app or program you 'just set up', so generic advice only. Somewhere in the Settings, for instance 'Settings - About' in Facebook, it says 'Gender' and there you would change from male to female. Then the Avatar option would all be female. Help here on various apps https://www.google.com/search?q=change+male+avatar+to+female ..
12/25/2022 9:49:10 PM • Option Computers... • Answered on Dec 25, 2022
Is imitation jewellery a good product option for export from India to other countries?
Why not? imitation jewelry are acclaimed in India as well as another county like UK, USA, Canada etc. In fact in other country indian imitaion jewellery are leading nowdays. The leading major market of imitaion jewellery in other countrys is Indian. They order imitation jewellery in bulk. so if you want to export imitaion jewellery from india then this is the good idea. Good Luck.
11/28/2022 7:23:09 AM • Option Computers... • Answered on Nov 28, 2022
My dvd is talking German When I change it to English The tick stays on German. When I click OK it stays on german.
NO DVD title told , nor region code of DVD. disk no DVD PLAYER told , is it TV or PC or ? just DVD lap player dedicated to DVD only.? (some player (apps) are horrible) DVD's do not have to support 150 languages, that is the producers choice.(voice, CC and subs) try the DVD in PC yet? see if it works there using VLC free player ?????? factoid wiki (25 car common) While the fact that there are 6,000 languages sounds a lot, 75% of the world's population can speak with just 20 languages. https://localizationlab.com/how-many-languages-are-spoken-in-the-world/ free and safe runs on PC and plays most things.(disks or files) https://www.videolan.org/vlc/
8/29/2022 11:46:24 AM • Option Computers... • Answered on Aug 29, 2022
I have a Sinotec channel av-100 and the display window does not come on
Hi, please shutdown your device/system for 10 minutes before powering it on again. If this does not work, please check your device's manual within the table of contents in order to use the troubleshooting section to overcome this issue. Thank you.
7/29/2022 10:42:33 PM • Option Computers... • Answered on Jul 29, 2022
How can I totally stop the BIOS option from coming up when I switch on my laptop?
REplace the exhausted back up battery.
7/15/2022 9:44:20 PM • Option Computers... • Answered on Jul 15, 2022
2answers
Why League of Legends is not playing after upgrading to windows 10?
We need to know what hardware is in that machine because it sounds like a direct x issue with AMD graphics card. http://boards.na.leagueoflegends.com/en/c/help-support/AnR7gUle-will-windows-10-and-league-of-legends-be-friends
7/12/2022 1:30:39 AM • Option Computers... • Answered on Jul 12, 2022
2answers
Converting .DBX files of Outlook Express to .PST in MS Outlook
The ToolsGround Outlook Expres to Outlook Converter tool can migrate all of your files without any data loss and changes in your files. You can easily select your files before migrating. More Info:- Outlook Express to Outlook Converter
11/10/2021 9:18:09 PM • Option Computers... • Answered on Nov 10, 2021
2answers
My camera says Card is not be formatted.
Make sure the little No-Write tab is set to open (open padlock symbol). I have a card reader on my computer, so I can format there and if necessary, in the camera as well. Sometimes the cards just become corrupt, or at least the file system does.
8/17/2021 10:51:21 PM • Option Computers... • Answered on Aug 17, 2021
How do I get a user manual for a conair ww41 scale?
WW41 doesn't appear to be known by Conair. How about a 66/68. Link yo the maker on the last page. https://www.conair.com/assets/files/ww66-weight-watchers-bathroom-scale-instruction-booklet.pdf ..
7/1/2021 6:56:34 PM • Option Computers... • Answered on Jul 01, 2021
I saw i option you published i tryed it Worked
Please don't post followups as new posts. Post as a COMMENT under the name of the person you are replying to. In this case ME! Posts here are not threaded or nested by poster so this post has no context to the others. I am pleased you managed to sort it out., https://www.fixya.com/users/hugh-russell *tried :>) ..
2/4/2021 10:23:55 AM • Option Computers... • Answered on Feb 04, 2021
Slide show expressions, i want to make a slideshow and post it on web. I have only one option to write it to a DVD? No one uses DVD's any more it is all about streaming
If you are posting it to your own website, your website host normally has a slideshow widget which you load to the site and then upload the images.orthere is a Gallery and there is a slideshow option.or you can make the slideshow in PowerPoint and upload that and add a link to PowerPoint Viewer.
1/30/2021 3:07:49 PM • Option Computers... • Answered on Jan 30, 2021
Option iCON 505 HSUPA/HSDPA USB Modem Logo
1 questions posted
Popular Products
Top Option Computers & Internet Experts
 Mikey
Mikey
Larry Ng
Larry Ng
ADMIN Eric
ADMIN Eric
Are you an Option Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Option Computers & Internet
Most Popular Question
ecco tv sign in netflix its showing
  • Computers & Internet
