20 Most Recent
IBM (01K2154) Sound Card Questions & Answers
Not acctive sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(appropriate speakers) also audio you will find 3 drop down lists make sure you have the correct settings there
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
How can i repair the sound problem cause due to
if you mean after you have upgraded from xp to windows7
click start right click on computer select properties then device manager scroll to sound and video game controllers if you see a yellow question/exclamation mark or a red X the driver will need to be updated
if you computer came with a motherboard disk the drivers could be on it although once speakers are connected widows 7 should automatically update the drivers
click start control panel hardware and sound manage audio devices playback you might have to set a default go for via high definition audio then right click on speaker you might have to configure them then
select properties you will see tabs general level in this tab make sure your setting are loud enough also enhancements and advanced from the drop down list in the advanced tab select dvd quality or another then apply
hope this helps you
Audio device problem
(((appropriate speakers)))
settings there
also
untick it
if his does not fix the
problem
sounds and audio devices you can adjust the volume there also select speaker
volume you can change your settings there you can also tick in the box place
icon in taskbar for any further volume control settings you will need to right
click on the volume icon system select
adjust volume
audio,volume,advanced,speakers select the appropriate speakers from the drop
down list or navigate to the device manager scroll to system devices + to
expand,system speaker right click properties then select use this device
(enable) also you might check
the speakers plug/outlet is
usually at the back of the computer you will have to open up the computer
to check the lead attached to the rear of the input plug make sure the
connection is good
try cleaning your computer of dust using a fine air blower from a
compressor making VERY sure that there is no MOISTURE in the air line
specifically around the sound card and the CPU central processing unit dust
causes static to build up in a computer hope this
helps
My ibm thinkpad laptop has
Try installing the latest audio driver.
The same model ThinkPadcan have different types of network, video and audio drivers and unless youknow exactly which one is installed in your ThinkPad, you need to download allthe drivers and install each driver until you find the right driver.
When you download thedrivers, write down the device driver and it's file name so you have a recordof which driver you are installing and which directory the unzipped files arelocated on your hard drive.
Go to the IBM/Lenovo WEBsite - support/download page and download the latest Windows device drivers foryour model computer, Use this link: -
http://www-307.ibm.com/pc/support/site.wss/product.do?template=%2Fproductselection%2Flandingpages%2FbrowseByProductLandingPage.vm&sitestyle=lenovo&brandind=10&validate=true
You can download thevarious drivers and then you click on and run the various driver files, theywill then unzip and expand into a sub folder on C:\drivers Then install thevarious drivers from this folder (run the set-up file).
I can not hear any
Hello elkam82, you have to "Update the Drivers.
Part1
Do a [Microsoft Update] from the "Start Menu," scroll in the "All Programs."
Do a "Windows Update" Type: windows update, in the Start Search {box}.
Go to the "Control Panel" from the Start Menu," open the Control Panel.
Scroll to find "Hardware and Sound," and click on the "Sound" applet.
Open the Speaker Properties
Click on the [Driver Button] and "Update Drivers for the Speakers"
Part 2
From the "Desktop Screen."
[Right / Alt] click on the Volume Icon.
- Once the 'window' open!
- Select the "Playback Device" shortcut.
- Click on the {MIC Icon} to "highlight!"
- Next, click on the [Properties] 'button.'
- Now, check the (Device Usage) to make sure that it is [Enable].
- Next, check the "Levels / Enhancements..."
- Clicking on the buttons to open
- Make sure, that "all the levels on the 'Sound are 'Up!"
- Next, go to the "Drivers" by clicking on the "Properties" button.
- Select the [Driver] button, and "Update the Drivers."
- ***Note: "If any of the Driver {Areas} are "Grayed-Out?"
- Than this mean that the "Drivers are up to (Date)."
Click on the "OK" button when finished!
Next, "Restart the Computer."
Part3
Open the "Device Manager," from the [Control Panel > Hardware and Sound], and 'check' to see if the "Sound Card" is "present?"
If the Sound Card is "listed?"
Next, {2x} click to open, and "Update the Drivers"
"If this information helped? Return and give a "Helpful Rating," please!
Thanks, paul7of9"
I dont have sound in my computer
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
don
I lost driver installation
U can download drivers from nodevice.com.
Choose category,choose subcategory(depend whether u have it or not)
U are done just click download
I dont have sound on
A general case might be to take the stereo headphone output of the laptop and feed it a set of left and right line level (not microphone level) inputs to the soundboard. Radio Shack sells a cable that has a typical mini stereo headphone plug on one end and a pair of RCA Phono plugs on the other end. If the soundboard does not have phono jack inputs you will need some type of adapter plug on the ends of the cable phono plugs to match the soundboard's connector.
You then experiment with the laptop's volume control setting (start low) and the soundboard's input level control to get undistorted sound with minimum noise and hum. If you can not get rid of the hum, you probably need to add a ground loop isolation box (also available from Radio Shack, I believe) to reduce or eliminate the hum.
__________________
I can't find ibm sound
1st Download Driver from this site
IBM Sound Driver
Installation of Sound Card.
- Go to the control panel
- Click on the System Icon
- Click on the Hardware Tab
- Click on the Device Manager then
- Select the Multimedia Controller or Audio Control the yellow Question Marks sign on it.
- Right click on Multimedia Controller and uninstall it.
- After this go to the top of the device manager and click on scan for hardware changes.
- Driver installation Wizard start.
- Brows Your Driver from the Hard Disk and click on next.
- Driver will be install.
HI I DOWNLOAD NEW WINDOW XP THEN AFTER I DONT HAVE
IBM Sound Driver
- if the problem is still exist.
- Replace the sound card or have a local tech take a look at the sound card.
Ibm sound card drive
The motherboard (IBM FRU 13R8926) has on-board ADI SoundMax audio. It's used in a variety of IBM/Lenovo desktop computers- including ThinkCentre A50p and M50. This should be the download page for the A50p and M50 models:
http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-50534
You should be able to use the ADI driver-only download on newer (x86) versions of Windows; although it indicates 98SE/2000/XP, version 5.12.01.5410 worked fine on my Windows 7 Professional install.
IBM/Lenovo lists drivers under the system model number, rather than by component, but you can search the IBM and/or Lenovo site for the FRU number (13R8926, in this case) to find the systems that it goes with, and then pick one of those systems to find the relevant downloads.
