20 Most Recent
Frymaster Dean 2424G Deep Fryer Questions & Answers
I have a frymaster sr14esd, it turns on and makes noise but does not heat up. Is it my thermostat?
If the unit seems to be powering up and making noise, then you have power and it doesn't sound like a tripped breaker. About the only noise I would expect would be the element heating up and maybe the oil popping unless there is a fan. What kind of noise is it making? IF you have the equipment & know how, you could confirm power to the heating element or check the load the item is placing on the electrical service. One way to check the thermostat is you can turn the Tstat all the way down, turn on the power and see if you can hear the power engage as you slowly bring the temp setting up.
How do you reset high limit switch
Should be right under the panel where near the temp control know, will be a little red button its pretty small so you have to look close.
My penny broaster smells like burn plastic
Check the wires at all connections for burnt insulation. This could be where your smell is coming from. Also make sure something is not burning the well if it is plastic.
My fryer heat up to 285 then quit then try to
sounds like the high limit is doing what it is suppose to do. Check the actual temperature of grease with a perometer and see if it matches temp on computer if it is more than 10 degrees off or fluxuates irraticly change the temp probe. If it is dead on change the high limit.
The pilot is on but the switch won't turn the
I can tell you from my own experience with fryers, that they take quite some time to heat up....before lighting.... The probe takes some time to get hot, before it will kick on and light. You normally have to hold the light button on for some time, before the manual fryers will light. I have helped many a customer who cannot seem to get their manual gas fryers to light, and normally it's because they don't hold the light button down long enough. The sensor in there takes alittle time to heat up and it tells the fryer it's time to light. I think people get alittle scaried with gas and just don't hold it down long enough. Try holding that button in longer first, then light it... It should work. If not, call us and we'll try to walk you through it.... Our service tech is Ray, and I'm Susan with Restaurant Equipment Outlet, Cincinnati, Ohio, 888-542-5959. Thanks and good luck, Susan
Wont start up pilot is lit and thats all it will
Here are some pointers:
Check first if the unit receive standard gas pressure required on the nameplate.
Ensure that the thermopile is free of soot or any form of dirt.
Pilot flame quality must be good so that it can properly heat up the thermopile.
Gas valve knob must be turned to "ON" position after the pilot is lit.
Thermostat set at temperature higher than present oil temperature.
Wires are all tightly connected on terminals.
Regards.
