20 Most Recent
Neptune MLE2000A Front Load Stacked Washer / Dryer Questions & Answers
Maytag neptun tub doesnt spin during spin cycle
The spin enable switch located on the door lock assembly is the most suspect failed part. Sometimes there are one or more sensors connected to the out of balance circuit that can cause a no spin condition. Lastly if your serial number qualifies, you will need a motor conversion kit as this failure can cause a no spin issue. Pleazer Appliance...
Water left pooled inside maytag neptune front loading washer
Possible explanation: Some water is left in the hose going up to the drainpipe b/c the pump can only pump water with water, not air... so when the last bit of water is sucked up, it 'stays' just the other side of the pump exit nozzle and keeps the drain tubefilled. This water gradually leaks thru the drain exit valve and back into the machine, sometimes siphoning standing water in the drain trap with it.
The valve is either electric solenoid or plastic/rubber clapper in a cylinder. Your call whether to fix or not depending on ease and cost. Probably a $20.00 part.
Cheers!
NEPTUNE MAH5500BWW WASHER , WANT TURN OFF, OR START,,LIGHTS ARE LITE UP,,,AND ANY BUTTON PUSHED CAUSES IT TO BEEP A FEW TIMES,,,NO ERROR CODE...TRIED UNPLUGGING TO RESET,,,NOTHING
Sounds like a control board malfunction.
