I have a feeling it's the ribbon cable to the LED light bar on the one side. I made a video showing how to replace the ribbon cables to the light bars.
Dear Cheryl,
The power cords are pretty standard from all theses TVs.
Please remember that these power cords have 3 pins (male side), being 2 flats and 1 round that connects to the wall. On the other side it also has 3 flat pins cast into the plastic/rubberized female side. These are standard power cables for the majority of the sound/video equipment you will find in the market.
If the connector at the TV (male) is of the same type in power cord you have (female), in other words, if it fits and completely locks in, then, YES! Go ahead and use it. There is no problem whatsoever.
IMPORTANT - BEFORE CONNECTING THE CORD TO THE WALL ("live" power), please test if your connector fits the TV set completely.
I hope I have helped you.
I happen to have the same tv brand, size, and problem. The only difference is model. I bought mine black friday 2012 and its got screen problems. Im looking for a solution also to why it has the problem it has. It was working great for the time being until i noticed cloudy white spots around the perimeter edges. I found out its do to a few possibilities. One is the one thats wrong with mine that i believe is dead pixels. My tv doesn\'t look damaged in the screen butt when the image darkens while watching tv u can see it. Its like a bleeding discoloration. Me personally im taking mine back to either get my money back or new tv. From ur breaf description sounds like u have the same issue except yours came that way.if u look at my follows on here u will see pictures of my tv and the issue to my screen. I bought mine from best buy. So i got a thirty day store return warranty plus i purchased a 2 year warranty. So im going back and going to see what they are going to say. I advise u to probably do the same especially if u got warranty. As far as changing ur setting for HD picture quality with ur dish is to go through your menu options on the dish.i use comcast so mine is different butt im sure in a way the maybe might b in somewhat similar. With comcast theres a format button on the front of my box that i can press to change different format quality. If that dont give u what your looking for then see if you turn off your box while tv is on and then press menu on box and see if a user menu pops up if so then u should be able to change quality. You then can program it to be 1080 if ur using hdmi or components. One thing with comcast box is that i can make every channel 1080 bt the regular channels that dont broadcast that quality makes the picture smaller. So then u have to have HD channels to get 19080 quality. Butt u can get a good quality setting still with regular broadcast channels by overriding to 480p or to the best quality its puts out to that channel. Most broadcast channels set out a 480i or a a better HD 480p. Other than that you have to have HD channels and then ur box should automatically format to 1080u quality on the HD dish channels so you dont have to keep changing. Then when change ur channel back to standard broadcast channel it will automatically format to back to 480peither and so one as you change channels. Well hope it all helps and you got what you were looking for.
480 I is standard definition, look to see if set is 1080 as indicated here, it would need the 1080 signal hooked to the correct input for this.If stains or any kind of screen issue they may refuse to exchange set if not reported very quickly===if you paid good money get what you paid for-----too many people just say---ah ok I guess.....
All type and all type repair is availble in Dubai at just one little call/email/msg - +97145864033 , info@uaetechnician.com . Amazing experience computer repairing near me and prompt service. Nevertheless, since our laptops and computers are so expensive, we should always opt for a better alternative.
This is not an error code you have accidently activated the delay timer. This timer delays the start of your wash programme & can be set between 1 & 24 hours so a wash can be done overnight or when at work for example.
To deactivate the timer press the delay timer button until it shows '00' (sometimes +/- buttons)
Hola Necesito informaci?n sobre el acceso a los canales mediante antena
marca Westinghouse
modelo UW40T3PW
norte serie 6590Y20500205
Tipo de Exploraci?n de canales ATSC
It could be used as a monitor if you have on of thoose advanced Digital Tuners, They usually have a DVI or VGA port.Especially the HDTV ones. Connect thoose and you're off. If your monitor supports TV tuning, just connectt eh cable straight away and you should be able to watch TV. I would use digital tuners since they are becoming Widely avaible.
westinghouse the security system the system is beeping when i disconnect it shuts....Download the manual. I can't remember if it is in the User's Manual or the Programming Manual but a sequence to reset the security code is detailed in one of them. Also, it sounds like the telephone line was wired through the system for full seizure. To defeat this, you will need to take it out of the phone lines at the outside telco box. How it is wired is that the alarm panel intercepts the telephone line first and then feeds the circuit back out to the main junction where the telco comes into the house
