20 Most Recent
Indesit 24 in. DE73 Evolution Free-standing Dishwasher Questions & Answers
Dishwasher tablet not releasing
We had the same problem - we found that items on the top shelf were too far forward and stopping the dispenser from opening. Try making sure nothing is in the way when you shut the door.
A13 error code
It seems to me that there isn't any problem with the normal washing cycle. The problem you have could be related to your dishwasher's detergant dispenser lid. I reckon that the relevant part isn't functioning normally. You can simply check out the claws placed on the detergant lid. If there is a spring inside, it might be damaged.
Error code AO1
Error message A01 means -Acqua stop operated due to a leak or overfill. Check if there is still water in the machine after it stop pumping. In case you still have water - your problem is with the pump or with a blockage drain line.
If there is no water in the machin, it might be a water level sensor issue - stuck physically in the high level position or become defective.
Try to reduced the water presure and leveled it up by the water entrance tap to the machine, it might solve your problem.
Goog luck !!
Indesit IDL 50 Dishwasher
Had a similar problem (flashing lights 1 and 2). Drained the machine by diconnecting the outlet hose and using a shallow bowl on the floor. Removed and cleaned filters. Forced clean water through by using a garden hose pipe(you can only do this one way, you cannot force water down the outlet pipe). Removed and cleaned the pump (you have to do this from under the machine but easy enough). Finally ensuring the waste trap under the sink was clear. Bingo!! No parts, no expensive engineer.
Hello
As you correctly pointed out A13 error is linked to the failure of the detergent dispenser lid operation.
If the lid is not opening at the correct time in the wash cycle, then the detergent will not be getting dispensed.
Either the controller circuit that operates the lid is faulty or the lid solenoid is faulty.
You can check the parts at
this site.
Led states A05 problem and machine stopped working
"Error A05 - Pressure switch has not been reset "
This is centered around the filter and drain area not working properly.
It is possible it just needs the filter cleaning and the hose flushing out, but also possible the pump needs to come out to clean it properly.
Drain it by putting the hose low down, and clean the filters of debris.
If this does not fix it, then remove the unit outside, lie on it's back and remove the pump to clean it.
