20 Most Recent
Excel (SS8SATAS5128400R) Questions & Answers
Protect excel
Hi SAJID MEMON,
This one is a little hidden, it's an option under the save as window. So go to file->save as then you should see either a down arrow on the save button, which opens up a sub menu or a tools option in the top right. Under tools select general options, then you should see the password options there.
5/4/2018 1:30:42 PM •
Excel...
Answered
on May 04, 2018
How to recover password protected excel files
You will need recovery software to recover password for the protected files
here is the linklink1Excel Password Remover 2008
Low feed backs hurt my ratings and I tried my
level best to resolve the issue. so please show your appreciation by rating it.
Thanks for using fixya support..You have a wonderful day
2/3/2018 11:34:22 AM •
Excel...
Answered
on Feb 03, 2018
Excel
If you don't have MS Office, then you will have to purchase either the Excel component as a stand alone but you would be better off with the whole MSOffice as it contains your Word processor, Database, Excel, Powerpoint presentation software and in the 2003 version also Publisher.
It is not too badly priced anymore, but if you cant afford it then you may be able to borrow a copy whilst you are doing your course from a friend, but you will have to uninstall it afterwards.
1/6/2015 11:56:54 AM •
Excel...
Answered
on Jan 06, 2015
Have a used laptop excel
MS Excel is not afree program.
You will need to purchase a copy of MS Office which includes Excel.
For an alternative free program
OPEN OFFICE is a full-featured officesuite that's compatible with Microsoft Office.
If you want Open Office you can download this free program.
Click on this link to download :-
http://www.openoffice.org/
3/3/2011 1:07:03 AM •
Excel...
Answered
on Mar 03, 2011
Remove excel password
HI!
Just go to google.com and type the following into the search box.
Excel Password Unlocker free download
and find a free office password unlocker.
most password unlocker tools do not give you the password to unlock your workbook, they just go into the system workings and unlock the entire workbook for you.
save a copy of your locked up workbook. only try the breakers on a copy, just in case.
6/10/2010 1:56:03 AM •
Excel...
Answered
on Jun 10, 2010
FORGOT THE PASSWORD
Hi SAKHIE
You need to run a utility, link below
http://www.straxx.com/excel/password.html
1/18/2010 9:53:06 AM •
Excel...
Answered
on Jan 18, 2010
Excel password removing
could you please supply us with the version of Excel you are using? it's under Help About Excel
1/13/2010 8:05:57 AM •
Excel...
Answered
on Jan 13, 2010
Excel question
You can import data from one sheet to another. If you want to bring a total from Sheet 1 to Sheet 2, then in Sheet 2 enter [=sheetname!cell] (without the brackets of course. You will now have the data from Sheet 1 in a cell in Sheet 2 and you can do anything you want with it. One note: if the sheet name has a space in it (Sheet Name) you have to enclose the name in single quotes; that tells it that the whole thing is the name. For example, Monthly Sales, A10 is the total for last month; to put it in this month for a running total, you would enter in Sheet 2 ['Monthly Sales'!A10] (without the brackets again). Now you can have a running total between the two sheets.
12/31/2008 6:21:50 PM •
Excel...
Answered
on Dec 31, 2008
Excel
Use the installer disks. Of course, you can switch to OpenOffice, which is free:
http://why.openoffice.org
11/12/2008 7:42:35 PM •
Excel...
Answered
on Nov 12, 2008
HELP with macro config
Hi Hss Holdings,
The easiest way to do this is to use a formula called vlookup. You need to have the raw data some where in the workbook, but it can be a separate sheet. Put all the raw data in a table, make sure the account number is on the furthest left column, then start entering the formulas
vlookup(value_to_find, table_to_check, column_index_number, range_lookup(true/false))
value_to_find = the value you want to find on the left most column of the table
table_to_check = the table you want to find the data from
column_index_number = the column number of the data field you want to return into this cell, 1 = the left most column.
range_lookup = false for an exact match, true for the nearest match
Say the table is on sheet2 between A1 and E300
B15 is whatever you type, so no formula needed here
B12 =VLOOKUP(C1,Sheet2!A1:E300,2,FALSE)
G12 = B12 =VLOOKUP(C1,Sheet2!A1:E300,3,FALSE)
etc
7/20/2008 6:46:59 PM •
Excel...
Answered
on Jul 20, 2008
Calculate a bill
Hi you can Apply below mention formula
=ABS(SUM(COUNTIF(RANGE,"CATAGARI")-(COUNTIF(RANGE,"CATAGARI")))
RANGE = FROM WHICH CELL TO YOU WANT TO APPLY THIS FORMULA TO TILL WHICH CELL.
CATAGARI = WHAT DO U WANT < FOR FOR FIRST > FOR SECOND
7/7/2008 11:09:36 AM •
Excel...
Answered
on Jul 07, 2008
Unable to Change Dates
I am using MS-2007, i got the solution upto some level only.
i can't say exactly whether it is right or not.
my solution is :
first change the settings in ControlPanel/Regional and Language Options.
Click on Customize button/open the Date Tab and set the date format there.
and then proceed with CSV.
Open CSV in Excel and divide Text to coloumns.
Ur all Date Cells will be in particual Format.
and Select that coloumns and right click Format Celss....etc.
Thanking u.
If u found any Douts, Suggestions ,Plzz let me know.
6/27/2008 9:03:10 AM •
Excel...
Answered
on Jun 27, 2008
Prevention of delition of cell which has a formula
If you right click the cell in question and go to Format Cells..., on the protection tab there should be a check mark in the locked box. Go to the tools menu and choose Protect and Protect Sheet, enter a password and your cells will be protected.
Any cells you want to allow changes to when the sheet is protected should have the Locked checkmark removed.
6/16/2008 2:04:51 PM •
Excel...
Answered
on Jun 16, 2008
