20 Most Recent i-mate JAM Pocket PC Questions & Answers
Prep Time:45 minInactive Prep Time:24 hr 0 minCook Time:1 hr 0 min Level:Intermediate Serves:10 (8-ounce) jars Ingredients
  • 1 3/4 pounds oranges, 4 to 5 medium
  • 1 lemon, zest finely grated and juiced
  • 6 cups water
  • 3 pounds plus 12 ounces sugar
  • Special Equipment: 10 (8-ounce) canning jars with rings and lids, funnel, tongs, ladle, and 12-quart pot
Directions Wash the oranges and lemon thoroughly. Cut the oranges into 1/8-inch slices using a mandolin, removing the seeds as you go. Stack the orange slices and cut them into quarters. Place the oranges into an 8-quart stainless steel pot. Add the lemon zest and juice and the water to the pot, set over high heat and bring to a boil, approximately 10 minutes. Once boiling, reduce the heat to maintain a rapid simmer and cook, stirring frequently, for 40 minutes or until the fruit is very soft.
While the fruit is cooking, fill a large pot (at least 12-quart) 3/4 full with water, set over high heat and bring to a boil. Place 10 (8-ounce) jars and rings, canning funnel, ladle, and tongs into the boiling water and make sure the water covers the jars by at least an inch. Boil for 10 minutes. Turn off the heat, add the lids and leave everything in the pot until the marmalade is ready.
Meanwhile, place a small plate in the freezer. Increase the heat under the orange mixture to return to full boil. Add the sugar and stir the mixture continually, until it reaches 222 to 223 degrees F on a deep-fry or candy thermometer, and darkens in color, approximately 15 to 20 minutes. You may need to adjust the heat in order to prevent boil over. Test the readiness of the marmalade by placing a teaspoon of the mixture onto the chilled plate and allowing it to sit for 30 seconds. Tilt the plate. The mixture should be a soft gel that moves slightly. If mixture is thin and runs easily, it is not ready.
Remove jars from the water and drain on a clean towel. Place a canning funnel onto the top of 1 of the jars and ladle in the marmalade just to below the bottom of the threads of the jar. Repeat until all of the mixture has been used. The amount of marmalade may vary by 1 to 2 jars. Wipe the rims and threads of the jars with a moist paper towel and top each with a lid.
Place a ring on each jar and tighten.
Return the jars to the pot with boiling water, being certain that they don't touch the bottom of the pot or each other. (If you don't have a jar rack, try a round cake rack, or metal mesh basket. Even a folded kitchen towel on the pot bottom will do in a pinch.) Add additional water if necessary to cover the jars by at least an inch. Boil for 10 minutes. Using canning tongs, carefully remove the jars from the water, place in a cool dry place and allow to sit at room temperature for at least 24 hours before opening. Once open, store in the refrigerator. Unopened marmalade will last for up to 6 months.
i-mate JAM... | Answered on Oct 26, 2018
we have no idea what you used as a password .not mind readers here
i-mate JAM... | Answered on May 11, 2016
you can transfer your text messages to your PC by installing a software on your PC called Jeyo Mobile Companion. download this software, install it and then connect your phone with the PC. once synchronized, you will be able to transfer all your text messages to your PC as a "Notepad" document! i hope this works for yah.. for your other question, go to start then settings, then "sounds and notifications", then go to the "notifications" tab, then in the "event" pull down menu select "messaging:new text message" and then check the "play sound" check box and then select any sound you would like. simple isn't it? ;)
i-mate JAM... | Answered on Jun 24, 2014
At the bottom of your Facebook page, click the language name next to the Facebook copyright, then choose your flavour/flavor of English.
i-mate JAM... | Answered on Mar 05, 2014
just from the file explorer select the file whichever u want to send with ur stylus for like 4 sec a menu will come up select beam file then ur device will switch on the bluetooth search for other devices to which u want to send the file to then that device will appear in ur list just tap and select the device from the list then send the file it will try to pair up ur device with the other device first put a code like 0 and on the other device also put 0 to finish pairing then ur file will be send press accept on the other side and go
i-mate JAM... | Answered on Nov 21, 2013
The operating systems on PDAs are different from the normal PC ones. The operating system is stored in the ROM of your PDA, and when you do a hard reset to your PDA, the windows is reinstalled from your ROM. And if there is no ROM upgrade for that particular device by directly from it's brand (sadly there is no ROM upgrade to any other version of windows for that device), you cannot upgrade your device's windows version. There is something called "Cooked ROMs" in the internet containing newer versions of windows, but they are illegal and risky. Anyway, your PDA is designed for that version of windows, including hardware, and newer versions of windows may not work correctly or completely slow down your PDA.
i-mate JAM... | Answered on Oct 20, 2013
my jam is a PM10A. and it doesnot have a radio.. check for urs..
i-mate JAM... | Answered on Jul 11, 2013
I cannot change settings of my i-mate jama 201 since it's in arabic. how can i change it to english?
i-mate JAM... | Answered on Jun 04, 2013
no you can't upgrade windows 2003 to windows 5 or 6. these windows doesn't exist.
i-mate JAM... | Answered on Nov 30, 2012
Good morning In most phones there is a help icon, there it is possible to get help with most things that make the phone work. Such as how to adjust the different functions to your needs. Enjoy your coffee Kolbrun
i-mate JAM... | Answered on Jun 22, 2012
yes Aadil, there is a bug in the operating system and the solution is that there is a patch file you can download it from www.clubi-mate.com , it's called camera patch it will solve the problem. i solve this problem in my i-mate before...
i-mate JAM... | Answered on Jun 08, 2012
You cannot upgrade to windows mobile 5 , but you sure can upgrade to windows mobile 6. I have i-mate jam with wm6.1 installed. Here is the link with this rom version. inside is a file with instructions : http://rapidshare.com/files/257201043/HTCMAG_ROM_WWE_O3.rar
100 % working
i-mate JAM... | Answered on May 16, 2012
Dear Shaya,
This problem related with configaration cnectionctions in your phone, so please let me know which network SIM yor using for further solutions, it is simple problem onece you know configaration.
Thx.
i-mate JAM... | Answered on Apr 28, 2012
reset the phone.. master reset.. on start up, it will ask a long message with "ACCEPT" and "REJECT" as choices. In that if u click "REJECT", it will install the interface in English. If you choose "ACCEPT", it will install in Arabic.
--Vidya, India--
i-mate JAM... | Answered on Apr 03, 2012
i-mate JAM Pocket PC Logo
523 questions posted
Popular Products
Top i-mate Computers & Internet Experts
Ekse
Thomas F. Schneider
Vincent G
Vincent G
Are you an i-mate Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • i-mate Computers & Internet
Most Popular Question
change language from arabic english
  • Computers & Internet
