20 Most Recent
Gigabyte GA-K8NSC-939 Motherboard Questions & Answers
Usb dont work on gigabyte GA-K8NSC-939
i have some suggestions1.the usb driver is not installed properly. if it's windows xp,you need to install it manually.you can download it free herehttp://ee.gigabyte.com/products/page/mb/ga-k8nsc-939/download/2.what device did you try to connect? it might be use USB 3.0 and your current USB is 2.0
8/22/2012 6:06:42 AM •
Gigabyte...
Answered
on Aug 22, 2012
Increased clock speed in bios, now there is no response at all
You might have overclocked it above the optimum speed. Try resetting the BIOS Cmos. You can do it by removing the CMOS Clear jumper or remove the system battery, re-install it after 5 minutes. Hope this helps. Let me know if the problem persists. Good Luck. Thanks for using FixYa.
5/5/2012 9:55:23 AM •
Gigabyte...
Answered
on May 05, 2012
My pc is slowing down dramatically and stuttering
typically the board will only recognize the largest memory stick and omit the others,. you may want to upgrade to the same mb stick --- I'd also check for viruses while you are at it
www.housecall.antivirus.com (trend micro) which has an awesome one which is free to use...
Best regards
Ck
2/16/2011 2:50:31 PM •
Gigabyte...
Answered
on Feb 16, 2011
What can cause the front
Usually its if the connector pins inside have been reversed putting power to where data should be.
What's changed since they last worked?
10/29/2010 1:00:09 PM •
Gigabyte...
Answered
on Oct 29, 2010
I have tried to install RAM up to the 4GB maximum
This RAID message has nothing to do with RAM, RAID is Redundant Array of Inexpensive Disks.
Maybe you knocked a connector when you installed the ram? This seems most likely to me, check all the hard drive connectors both at the drive and at the board.
Finally if you are not using RAID then disable it in the BIOS and it should boot without complaining, but I suspect you are using it and thats why its not booting, sounds like its set to use raid disks which it cant find because a connector is not in place, but thats just a guess based on what you're put above!
10/29/2010 12:56:26 PM •
Gigabyte...
Answered
on Oct 29, 2010
I have been using a
try to massage the your keyboard.. then open your pc..
after that clean up your memory ram... then put your inside the slot
again.. then try to open your pc ...
NOTE: THE LONG BEEP IN THE PC IS NOT A REFRESH ISSUE.. there was just a keyboard key stocks..
10/7/2010 9:02:44 AM •
Gigabyte...
Answered
on Oct 07, 2010
I instaled a new video card and now i get a error
It seems that you have not installed software DIRECT-X needed to run the big games. Check Game's requirements which may be seen in readme/manual. Check which version of DIRECT-X is required. Install the same from Games Cds.
9/22/2010 1:10:24 AM •
Gigabyte...
Answered
on Sep 22, 2010
My nforce3 chipset is very noisy now. can I replace this?
i think your cpu is generating too much heat thats why cpu's fan tries to cool down the heat. i think you need to apply some thermal paste . if you don't know what i am saying then i think you better take it to a technician to do it because it is complicated work.
6/18/2009 8:53:53 PM •
Gigabyte...
Answered
on Jun 18, 2009
Bios Failed During Bios Upgrade
pls check the RAM try re installing the RAM or try replacing them , may be it is a co incedent u thought it as a bios update failure pls check and reply back with mother board complete model number and manufacturer with processor details
and pls rate me if its helpful
3/18/2009 8:39:26 PM •
Gigabyte...
Answered
on Mar 18, 2009
Have not vista sound driver
hi im josh in cebu phils.may i help you. if the sound card doesnt work even you installed the driver.using vista. Friend to solve this problem you need to install manually your audio driver. go to my computer right clck then device manger then clck sound card icon then go to update driver then browse c prgram files.then look for sound driver then clck the run or setuo inside the folder. then ok. your problem is solved. good luck vote for me so that i wl knw if i helped you.
2/23/2009 3:08:04 AM •
Gigabyte...
Answered
on Feb 23, 2009
I dont able to format my pen drive when i open it
Hi
First u attach your pendrive with pc after that u do a right click on pen drive folder ,then u click on scan option then the scan folder will apper and u select the pen drive folder by adding ,then click on next opyion and wait untill the scan is over .After scan over's then u can format your pendrive....
Thanks for using fixiya
Rupesh Kumar
12/18/2023 12:36:15 PM •
Gigabyte...
Answered
on Dec 18, 2023
