20 Most Recent Gigabyte GA-6WMM7 Motherboard Questions & Answers
I HAVE PENTIUM3 OLD BOLD BORD.IF IAN CHANGE WITH THIS ONE asus ga-6wmm7 rev 2.0 motherboard
Hello here is the homepage:http://www.gigabyte.com/products/product-page.aspx?pid=1507#dlThe mainboards are the same type, but you need a new install of windows.Good luck
2/5/2013 2:51:51 PM • Gigabyte... • Answered on Feb 05, 2013
Find a compatable motherboard to
You probably have a Packard-Bell computer. You will need to match the motherboard form-factor to your case.
1/24/2012 5:33:09 PM • Gigabyte... • Answered on Jan 24, 2012
I can not get display
If you cannot get a display on your monitor, it's not a jumper setting. It's a hardware problem.Check the following: 1) is the monitor turned on and connected to the computer and is it actually working? 2) Has your computer actually started (has it passed the POST and have you heard the single beep on the speaker that indicated it has)?Try disconnecting all components except the CPU, memory, and video. If it still has no display, either your monitor is bad or the motherboard possibly has a problem.
1/24/2012 5:31:24 PM • Gigabyte... • Answered on Jan 24, 2012
Sata drivers required
You should not need SATA drivers if the motherboard supports SATA. However, you should update the motherboard drivers with the Gigabyte driver disk. If you don't have one, just go to the Gigabyte site and download them.
1/18/2012 6:04:30 PM • Gigabyte... • Answered on Jan 18, 2012
The packard bell motherboard i have is the ga6wmm7 alarm issues
I understand that your connections are snug, but that beep code means RAM issue. Humor me and swap the RAM in the slots. If that doesn't do it you may want to run Memtest or try other "known good" RAM.
5/4/2011 3:55:14 PM • Gigabyte... • Answered on May 04, 2011
I would like to download
hi you have to go to the gygabyte web page and download the software or the manual...if you get stuck please send message back and i will download it for you as a link to that motherboard...ps you can go on google web page type it in and follow a link from that
11/4/2010 2:34:35 PM • Gigabyte... • Answered on Nov 04, 2010
Additional 128 mb ram is
Remove all RAM, and eseat the new 128 board.
The new board MUST be :
128MB (1X128MB) PC100 NONECC UNBUFFERED 168 PIN SDRAM DIMM
If the criteria is anything but the configuration above, it will not work.
Also because of the type of memory, I am guessing the age of the board (or system) check to see what the max RAM is and see if your new board exceeds that amount.
Good luck.
10/8/2010 10:36:36 AM • Gigabyte... • Answered on Oct 08, 2010
Usb
go to bios and then perapherical setting there check usb port is enable or disable
if disable enable it
if u wanna go to a bios press "delete" button at start ur system
3/7/2010 8:34:03 PM • Gigabyte... • Answered on Mar 07, 2010
Hi ive got a GA-8TRC410MNF-RH Gigabyte mobo from a
as far as the SATA prob is concerned your mobo supports sata 2 as per the weblink
http://support.packardbell.com/uk/item/index.php?i=spec_SeagateTonkaII_Serial&ppn=PB34305801
2/18/2010 11:21:49 AM • Gigabyte... • Answered on Feb 18, 2010
2answers
Floppy cd rom or hard drive not recognised in bios
most probably the bios battery is week (that happened to me a few times on some old unused comps. ) ! Keep the computer pluged in for an hour or so ... and hopefully the next time u enter bios and set the booting devices, they will remain set 1
3/21/2009 4:35:52 PM • Gigabyte... • Answered on Mar 21, 2009
tip
Problems boot order on bios
my ga6wmm7 rev 1.5 boot order adjestment on bios not work only from flopy what can i do to boot from cdrom or hd? thank u
2answers
CHIP UPGRADE
Hello there.
As per here , the largest cpu supported is the 1.4GHz Pentium 3.
Hope this helps.
12/23/2008 12:55:40 AM • Gigabyte... • Answered on Dec 23, 2008
BIOS problem
Turn of computer re start and reset the BIOS through the motherboard BIOS Reset jumpers
8/8/2008 4:04:49 AM • Gigabyte... • Answered on Aug 08, 2008
4answers
I dont able to format my pen drive when i open it
Hi
First u attach your pendrive with pc after that u do a right click on pen drive folder ,then u click on scan option then the scan folder will apper and u select the pen drive folder by adding ,then click on next opyion and wait untill the scan is over .After scan over's then u can format your pendrive....
Thanks for using fixiya
Rupesh Kumar
12/18/2023 12:36:15 PM • Gigabyte... • Answered on Dec 18, 2023
Why my Gigabyte GA945GCM-S2C board GPU heat instantly
If it is not an accumulation of dust and if your fans are working properly and your ventilation is not blocked, that there was not a built-in cooling system for this integrated part makes me wonder what is going on. One would have thought it suggested such was not necessary. How old is the thermal paste in the computer? I would replace that before trying more desperate measures. Rather than presume the fan was working, I'd make sure that it was. Here are some causes and fixes: https://www.onecomputerguy.com/gpu-overheating/
10/15/2023 4:39:50 PM • Gigabyte... • Answered on Oct 15, 2023
Hey, I own gigabyte W566N
1/5/2023 3:23:38 AM • Gigabyte... • Answered on Jan 05, 2023
Ati radeon hd 7770 problem
no PC told at all no OS told either. sure a DESKTOP sure. no monitor told nor cable used, VGA, DVI,hdmi, DP i can not see your near black screen at all. cold booted is the PC splash screen dead./? all bios screen dead and all BIOS works even with HDD missing. idle black is sleep mode, a USA law mandates that. iof we do not like sleep mode we disable it in power settings CP CP means control panel this must be your first PC ever? and all go to sleep ,go to walmart see them all in sleep mode now, yes, a USA law called Energy star laws. and all wake up on demand new , unmolested. wiggling the mouse or hammering the space bar ends sleep but not if (again) power settings has USB going to sleep too. why post lacking Pc makers name and OS.windows what gee vast persons on earth ugraded w7 top 10 and now this fails. due to , PC maker told you , no w10 support in this secret PC 4 decades of 100,000 models of PC I can no no guess blind./ Radeon hd 7770 card and 80watt card in fact, oops.????? is this real ATI/AMD card or any of the other 12 makers of cards. ??????????? no full card number told and guess what the watts matter. 250watts is smallest watt PSU, or more if PC is loaded out like mine with 2SSD and 4 SSD and 1DVD and 1 Blue ray and max ddr and more. Power is first after fit, and yours fits so power is next PSU watts and what the card needs let me see that. all hits on this card show it crosses the magic 75watt rule for PCi-2 power of 75watts, and card is 80watts and more dynamically so they maker of the card has a 6 pin 12vdc aux jack that can not be ignored or the card fails, so is that wired up? as it must? yup top rear of card 6 pin aux power in black , steathy that, hard to see at 1st glance but 80watt cards need it, that and even 300watts cards are sold. does your card have red fan. see what I mean buy 12 maker of cars all with AMD GPU. the cards all have tag called the SKU tag or full model told for GPU speed and vram sizes and more, lots more. https://search.brave.com/images?q=%20Radeon%20hd%207770%20card# I have boxes full of old GPU cards here, stored. some need 500watt more PSU to even begin any 3d mode. only the SKU matters, wiki SKU. and what PC this is and what PSU wattage and if said PSU has the 2 AUX CABLES WITH DUAL 6/8 Plugs, (PCI-12v) marked. if not we can do adapters easy. ask
6/4/2022 4:14:14 PM • Gigabyte... • Answered on Jun 04, 2022
Gigabyte GA-6WMM7 Motherboard Logo
Popular Tags
20 questions posted
Top Gigabyte Computers & Internet Experts
MegaByteMe
MegaByteMe
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Gigabyte Computers & Internet
Most Popular Question
find compatable motherboard
  • Computers & Internet
