20 Most Recent
Gateway 700 XL PC Desktop Questions & Answers
I am not sure what plugs to plug into the compact
disk drives usually have two main plugs, one for power and the other is a multplug for system communication. power is small with only one connecter. the other multi connecters in the plug. they only fit one way in drives. Just match them up. Power/multi are linked in pairs so that you know which go to any one drive. there are at least two pairs in a desktop. if its a laptop only one pair and you have to take it apart to get at wiring. Desktop, just open case panel to access inside.
My gateway 700 xl doesnt boot
Unplug the power from you 700xl and from you monitor. Try removing the cmos battery and reinstalling it. Then, plug everything back in and try restarting. If it continues to give you the yellow light, you may need to replace the CMOS battery, especially if it is more than two years old. Another thing to consider is if your power supply is underpowered for the number of external devices you have plugged into it (i.e., cd, dvd, external hard drives, printers, pci cards, etc). Gateway installed very low powered power supplies in their 700xl desktop computers. Usually only around 250 watts maximum. If you are replacing the power supply with another 250 watt maximum power supply, and you have a lot of external devices plugged in, you may need at least a 350 watt power supply....if your CMOS battery is not the problem.
Why won't my gateway 700 s boot from cd
You need to open your from its BIOS page. The way you can do this is to restart it and once it starts up press the delete button repeatly until your BIOS page comes up.. From here you have to change what your comptuer boots from. Change it to boot from CD DVD rom first then the harddrive. once you have this done save and quit the bios and pop in your cd.
How do you transfer hard drive from old comp. to
For just the data, get an ide to usb converter and connect it to the new computer, and just drag and drop.
You cant move an entire hard drive to a new computer because of driver issues, but you can use windows built in files and settings transfer utility.
IDE to USB: http://www.newegg.com/Product/Product.aspx?Item=N82E16812232002
Blank desktop
I had this problem also, I found that running windows update and getting vista SP2 solved my problem. If this doesn't work, after you login in and you get the welcome screen with the spinning circle hit ctrl+alt+del and log off, then re-type your password and it should work, but you may have to do this a few times. I hope this helps! put a comment down if you need more help!
Boot failure: System Halted
if you know how to reset your rom chip you can get your computer running again your computer is set to boot from a remote main frame and its looking for those files which boot system with mainframes harddrive not yours
theres one other way to correct this problem go inside bios from bootup
and reset settings
Dvd cd rom drive reads code 10 on Satellite A205-S5825 laptop
http://support.microsoft.com/kb/310123 check error code 10:
1. update the driver: go the toshiba website, go to support, provide system info and look for knowledge base info related to your problem and also look for possible driver updates - post the model of your laptop and we'll help getting the page for ya!
2.
http://support.microsoft.com/kb/943104/
make sure the device is enabled in windows and in the bios.
also disable any advance features (check with toshiba if you have any.. .and make sure your driver is updated before), lastly play around with the settings (make sure the driver is updated before doing this)
and remember to try one thing at a time, test, then move on to try something else.. be patient and methodic.
post back with your findings!!
I have a Gateway LP2417 monitor and there's No sound.Hoe do I fix it,so I can hear the video that is playing?
This monitor may not have built-in speakers. It may have supported Gateway's monitor mounted sound bar. That sound bar connected to the 3.5 mm audio out on a computer and a DIN port on the monitor.
The simplest solution is to connect your source to appropriate speakers. Depending on your audio setup, you could connect the video source to a receiver with HDMI IN and HDMI Out (ARC), computer speakers or an audio extractor. (If you are using an HDMI cable between the Gateway LP2417 and a computer, you may need to reset the audio output to use basic computer speakers (3.5mm jack).) VGA and DVI connections don't support audio so I assume you are using the HDMI port.
I hope this helps.
1/18/2024 10:32:24 PM •
Gateway...
Answered
on Jan 18, 2024
How to make touch screen on gateway computer upside down and how to put it back?
f you want to use your touch screen on your gateway computer in an upside down orientation, there are a few things you need to do.
First, you need to change the orientation of the screen in the control panel. To do this, go to the control panel and select "Display." Next, click on the "Settings" tab and then click on the "Orientation" drop-down menu. Select "Landscape (flipped)" from the menu and then click on the "Apply" button.
Now that the orientation of the screen has been changed, you need to adjust the position of the touchscreen so that it is in the correct position. To do this, go to the control panel and select "Hardware and Sound." Next, select "Pen and Touch" and then click on the "Calibrate" button.
Follow the on-screen instructions to calibrate the touchscreen. Once you have finished, the touchscreen should be working correctly in the upside down orientation.
I hope this helps!
3/14/2023 5:41:18 PM •
Gateway...
Answered
on Mar 14, 2023
