20 Most Recent Gateway Essential 400 PC Desktop Questions & Answers
2answers
Network Computers
Assuming this is a market research effort.
Suggest you reference the following article:
http://www.entrepreneur.com/technology/pcworld/article185344.html
9/11/2022 10:20:32 AM • Gateway... • Answered on Sep 11, 2022
2answers
I need instructions how to burn DVD's on Gatewat
please check if it is dvd writer or dvd rom only, as on roms you cannot burn dvd...
5/6/2019 8:59:21 AM • Gateway... • Answered on May 06, 2019
2answers
Damaged USB Port
Ok I think the best method to "Fix" this would be to get your self a 4 - 5 port USB card, they are, real cheap, insert it into a spare slot, inside your PC, and install the drivers, if any, and use that one. And simply ignore the other one all together.
1/5/2015 9:52:49 PM • Gateway... • Answered on Jan 05, 2015
2answers
I have a mini-DVD that I would like to rip into my
Your best bet is to try and find out what kind of software was
used to burn the disk this will solve your problem
3/20/2014 5:28:58 AM • Gateway... • Answered on Mar 20, 2014
Where is my firewall
if you look in the control panel you will find it.
2/26/2013 1:16:15 PM • Gateway... • Answered on Feb 26, 2013
Bypass BIOS password for Gateway Essential 400
Hi Bilethkidtry removing the round cell battery located on the mainboard. This make take a while to clear the bios system. try overnight to be sure, then place the battery back and start the machine. All bios settings should now be at default settings. Hope this helps.
2/18/2013 4:06:19 PM • Gateway... • Answered on Feb 18, 2013
No erternet on computer cant
If u dont have network card in ur motherboard, take ur computer to a service shop and replace the board that has network compatabile ethernet card in it
10/27/2010 4:27:21 PM • Gateway... • Answered on Oct 27, 2010
2answers
My gateway essential 400 cant run newer programs
You can add hard drive if your system doesnt have enough space for the new programs. If the new programs installs well but is running slow or not starting, then you will have to upgrade your RAM and for better performance, fix one graphics card suitable for *********** board. If you can spend more, Upgrade *********** board and processor.
Thanks
Sherbaz
9/21/2010 3:29:20 AM • Gateway... • Answered on Sep 21, 2010
Gatateway desktop computer will not start up.
sdas sd
9/15/2010 6:10:28 AM • Gateway... • Answered on Sep 15, 2010
2answers
Ie8 opens vrey slow
download http://www.supereraser.com/
This will clean your registry so it will run faster like new again
9/9/2010 7:11:33 AM • Gateway... • Answered on Sep 09, 2010
HOW DO YOU INCREASE PRINT SIZE ON PC SCREEN?
You did not stated what is your operating system, if this is any flavour of windows and you have scroll mouse:
1. press and hold "ctrl" button on left side of the keyboard
2. scroll mouse forward/reverse till required size of print is enquired
If you do not have scroll mouse, not everything is lost:
2. tap plus or minus key on numerical keypad till required magnification is achieved.
Other method is to tap right mouse button on your desktop, select "properties" or "display properties" depending which windows and adjust display size settings til yo are satisfied.
Hope this little tips will help you achieve desired result, please leave note which method work best for you.
8/18/2010 2:52:24 PM • Gateway... • Answered on Aug 18, 2010
My husband changed the size of the print on my
If you are referring to Internet Explorer, you can click Page, Zoom, and change the zoom back to 100%. Firefox is similar, click on the View menu, followed by Zoom, and Reset. There should be similar options on different applications. Please let me know if this doesn't work, and if not, which application does this occur with?
8/2/2010 4:27:23 AM • Gateway... • Answered on Aug 02, 2010
I want a sound drive for my computer
You need to provide some more info, your model appears no where on the gateway support site
7/15/2010 9:18:59 PM • Gateway... • Answered on Jul 15, 2010
I downloaded adobe reader 9. When I tryed to get
You probably downloaded the upgrade version. Go back to Adobe's websitr and make sure you download the full version of Acrobat Reader.
7/15/2010 8:10:39 PM • Gateway... • Answered on Jul 15, 2010
Im not getting a compete picture when my computor
To correct this issue, follow the methods that are described in this section in the order in which they are presented until the issue is resolved.
These methods are designed for beginning to intermediate computer users. After each method, refresh Internet Explorer to check whether the problem is resolved. If the problem is not resolved, try the next method. Method 1: See whether pictures are available on another Web site loadTOCNode(3, 'resolution'); Sometimes the link to a picture on a Web site is broken, and that is why a picture is not being displayed. Visit another Web site to determine whether pictures are being displayed correctly on it. If they are being displayed correctly, then there is nothing wrong with Internet Explorer. Instead, the Web site that you are visiting might be broken.
If you can view pictures on another Web site, you are finished. If you do not see any pictures or if you cannot determine whether the Web site that you are visiting is broken, try clearing your temporary Internet files by using method 2.
Note If you use Internet Explorer 8, try Compatibility View. To do this, start Internet Explorer 8, click Compatibility View Settings on the Tools menu, and then add the Web site that you want to view by using Compatibility View. Method 2: Clear temporary Internet files loadTOCNode(3, 'resolution'); Clearing your temporary Internet files creates more space on your hard disk. If your hard disk is close to being full, this could affect your ability to view pictures on a Web site.
To clear temporary Internet files, follow these steps:
Internet Explorer 8
  1. Start Internet Explorer 8.
  2. On the Tools menu, click Internet Options.
  3. On the General tab, click Delete under Browsing History.
  4. In the Delete Browsing History dialog box, click to clear all of the check boxes except for the Temporary Internet Files check box, and then click Delete.
  5. Click OK to close the Internet Options dialog box.
Internet Explorer 7
  1. Start Internet Explorer 7.
  2. On the Tools menu, click Delete Browsing History.
  3. In the Delete Browsing History dialog box, click Delete Files.
  4. Click OK to close the Internet Options dialog box.
Internet Explorer 6 and earlier versions
  1. On the Tools menu, click Internet Options.
  2. On the General tab, click Delete Files under Temporary Internet files.
  3. Click to select the Delete all offline content check box, and then click OK.
Check whether you can now see pictures. If you still cannot see pictures, try method 3. Method 3: Verify that the Show Pictures option has not been turned off loadTOCNode(3, 'resolution'); If the Show Pictures option in Internet Explorer is turned off, you cannot see pictures. To determine whether the Show Pictures option is turned off, follow these steps:
  2. Click the Advanced tab, and then verify that the Show Pictures check box is selected under Multimedia.
  3. Click OK.
Determine whether you can now see pictures
Please rate me if this solution works for you
Thanks......Have a great time.
7/14/2010 11:25:32 AM • Gateway... • Answered on Jul 14, 2010
Hey i need information on the characteristics of
I will be happy to assist you with that.
I am providing you with the link please visit the link and you can get all the information on Linux disk less workstation.
http://en.wikipedia.org/wiki/Thin_client
7/11/2010 12:46:10 PM • Gateway... • Answered on Jul 11, 2010
7answers
Disadvantages of multivendor networking
Different Protocols, It is difficult to implement integrated security, Complex configuration of devices, Software Incompatibilties
6/24/2010 7:53:21 AM • Gateway... • Answered on Jun 24, 2010
The characteristics of linux diskless workstations
Might be just me, but are you asking a question of some sort or making a sales pitch?
6/20/2010 5:24:56 AM • Gateway... • Answered on Jun 20, 2010
Obstacles and incompatibilities that may arise in a multivendor
obstacles arise in multivendor networking
6/18/2010 5:40:50 AM • Gateway... • Answered on Jun 18, 2010
Computers & Internet Logo
Popular Tags
110 questions posted
Top Gateway Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Gateway Computers & Internet
Most Popular Question
characteristics linux diskless
  • Computers & Internet
