20 Most Recent
Kodak Esp 3250 All-in-one Inkjet Printer Questions & Answers
Printer showing error code 3802
To resolve the error:
- Upgrade your printer firmware to the latest version:
- Locate and select the firmware for your printer.
- Follow the instructions to install the firmware.
- If your printer firmware is already up-to-date:
- Press the On/Off button on your printer control panel.
- Disconnect the power cable from the back of the printer.
- Wait 10 seconds to allow the printer to reset.
- Connect the power cable to the printer.
- Turn the printer on by pressing the On/Off button.
- If the error continues:
- Open the printer access door.
- Remove and install the printhead.
- Close the printer access door.
- Follow the on-screen instructions to calibrate the printhead.
NOTE: If you are not prompted to calibrate the printhead, turn off the printer, wait 10 seconds, then turn on the printer
My scanner want scan
Re-install the software but do not connect the USB cable immediately. Begin the installation and let the software tell you when to re-connect the Usb Cable to the computer. Let it finish
Reboot computer and Windows will find it.
Or, go in control panel and click on Scanners and Cameras. You should see the Kodak icon there. Click it and scan from there. If the scanner was well installed, it should work from there as well.In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On :
Kodak Printer Support
