20 Most Recent
Gateway 7320GZ Notebook Questions & Answers
Lost wireless internet connection.
Before you replace the network card (which is pretty easy on a desktop, a little trickier with a laptop), reset your router. Look for the router reset button and reset it (you need a paperclip).
Gateway 7320GZ restore problem
are you able to do a system restore back before the upgrade which I am almost sure you did right, take the computer back in time to the upgrade you were able to do with it, like if you had xp upgrade to vista, you don't need the 16 digit number, if this is windows that is, if this is a gateway computer this of course wont work.
Overhaeting
open the case, clean the fans and remove all dust from the comp. Also if u have oil the fans (special electonics oil)
The laptop overheats and then shuts down
Hi joshua1156,
Your laptop fan is not working. That's why the laptop overheats and shuts down. Replacing the fan will solve your problem.
Thank you for using fixya,
Arun Zac
Have a gateway 7320 laptop, I'm trying to take it
you can pick this component up in many electrical specialist shops or even try to ascertain the exact replacement part from the manufacturer.Try to measure its dimensions so the replacement will be a correct and easy fit.
Gateway 7320GZ works perfect for a few days then
I have pondered this situation for a bit and really am kinda stumped! Usually, things work or they don't. I would suggest that you check for a hardware diagnostic program in your computer, such as Dr Watson. I have included a link to the gateway support page for your notebook.
http://support.gateway.com/s/Mobile/Gateway/7305GZ/4430nv.shtml
If you know the manufacturer of your hard drive, you can go to the manufacturer site and look for download link and find the hard drive diagnostic program that most manufacturers offer to check their hard drive functioning.
You can also chat with a gateway technician and they may have some idea about this issue if they have had this complaint before.
I am sorry I could not be more specific.
Brian
Screem oroblem
You may be able to lighten it up with your keypad if not the screen or video inverter is bad.
