20 Most Recent
Gateway M1200-3004265 Tablet PC Questions & Answers
Operating System Not Found
Hi and welcome to FixYa,
Almost always, your described problem indicates a hard disk problem: either it is no longer recognized (most likely) or the partition / files are corrupted.
Good luck and thank you for using FixYa.
6/25/2009 12:25:58 PM •
Gateway...
Answered
on Jun 25, 2009
Free download of above driver
What is the serial number of your gateway computer? http://support.gateway.com/support/drivers/dlcenter.asp?cmpid=topnav enter it in here and select the drivers you need.
Thanks,
ArmyMason
2/25/2009 8:13:03 PM •
Gateway...
Answered
on Feb 25, 2009
Tablet CX 2620 Display problems
You should angle the screen towards the light to see if you have a faint image on it. If so, the problem is more than likely a failed inverter, or CCFL lamp on the LCD itself. Either in which would have to be replaced. The CCFL lamp unfoutunatly part of the LCD it self and cannot be replaced seperate the screen. The inverter can be replaced easy as it it right under the screen. Symtoms of a failing CCFL could be the white comes out as red on the screen for the 1st 10 sec or so of startup. This will put alot of stress on the inverter causing the inverter to overheat and shut off. I have one to where the CCFL failed and am trying to find a replacement.
Good luck
12/21/2008 2:26:28 PM •
Gateway...
Answered
on Dec 21, 2008
Need touchscreen drivers for Gateway M1200
I just bought one of these used, It had a fresh intall of windows XP tablet. When I got it the touch screen would not work. I have tried dowloading the drivers. I download Motion dashboard for this model. When I open it is says" Dashboard can not be run on this computer" I dont know what to do??
9/10/2008 11:26:14 AM •
Gateway...
Answered
on Sep 10, 2008
Motion m1200
First be sure that you are running windows XP tablet edition, then download the drivers from motion computing. This is the link:
http://www.motioncomputing.com/support/driver_download_1200.asp
If you are running windows XP regular not Tablet PC edition it is not going to work, toush pad and buttons only work on tablet edition.
This solve the problem.
9/10/2008 11:15:09 AM •
Gateway...
Answered
on Sep 10, 2008
