20 Most Recent
Sony BRAVIA KDL46EX720 46 Inch 3D 1080p 120Hz Smart TV LED LCD HDTV Questions & Answers
HOW DO I CHANGE MY SONY LED TV FROM ARABIC WITH ENGLISH
You would need to do a factory reset
From the Sony Forums:
factory reset to your Television.
- Turn on the TV.
- Wait approximately 40 seconds for the TV to completely start up.
- On the TV remote control, press and hold the UP ARROW button.
- While holding the UP ARROW button, with your other hand reach around the side of the TV and press and release the POWER button on the TV set.( not the power button on the remote) it should be the top button along the side panel.
Remove demo mode
A reset if the sony above might cure this but usually it is a combination of front buttons--most common is vol up and channel up at same time for several seconds.If that fails let me know and I will tell you the usual way to reset the set.
Sony Bravia 46 XBR has the input bar stuck at the top of screen.
Unplug the TV for a while and hopefully, that should reset the circuity. If you're using the original remote control, check for the display button and press it.
I would also suggest doing a factory reset if your TV has that feature and if the TV allows you to do it after unplugging it.
I need to remove the back off a Sony Bravia KD-48X81J
The front and back pieces are like a clam shell and are compression fit with tabs into one another. You need to use something like a guitar pick or spudger to separate the pieces. Dont use metal objects due to damage that will happen to the plastic .
