20 Most Recent
Emerson Lc320em1f TV Questions & Answers
Why wont my emerson tv turn on?
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
3/25/2016 12:57:38 AM •
Emerson...
Answered
on Mar 25, 2016
Tv wont turn on
Short circuit protection circuit activated, due to any electrically shorted component/s at its main board. Contact any service technician. If you wish to get some details, check the site linked here.
http://electronicshelponline.blogspot.com/Pull up older posts. Check the site in '
Mosaic' view.It will make search easy.
1/5/2014 3:19:08 PM •
Emerson...
Answered
on Jan 05, 2014
32" emerson tv
I would suspect the power supply first Most likely bad capacitors. The main board would be suspect next as the power on command comes from the main board which switches on the run supplies.
11/1/2012 11:32:41 PM •
Emerson...
Answered
on Nov 01, 2012
