20 Most Recent
Toshiba e-Studio 207 Copier Questions & Answers
E03 error in toshiba e studio 207
Power-ON jam:
The paper is remaining on the
paper transport path when power is turned ON.
1) Check if the connector of the sensor is disconnected.
2) Check if any of the connectors on the MAIN board is disconnected.
3) Check if the connector pins are disconnected and the harnesses are open circuited.
4) Replace the sensor.
5) Replace the MAIN board.
Toshiba copier
for e207 model, error code should be in C44, F14, and etc...
Assume your error is C43, check the fuser thermistor, clear the error using 08-400 = Any value => "0"
Toshiba 207 -f14
Hold down the key's "0", "8" and start the copyer.
After that it will apper (AD) or (ADJ), tst "389" and press the start key.
Then turn off the copyer and turn it on again,that's it.
Error c550
bad communication between adf and main board, change adf circit or main board
C44
Fuser error. Try resetting error status flag to 0 in 08-400. If it doesn't reset, possibly blown thermostat. If it does reset, and code returns after running copies, replace thermistor.
