20 Most Recent
Samsung UN32EH4000 32-inch LED TV Questions & Answers
I would like to know on how to reset a 32 inch chinese made samsung plasma
tv from burning mode
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
7/7/2016 2:54:13 AM •
Samsung...
Answered
on Jul 07, 2016
Need tv code for model un32eh40031
This should help!
Turn on the TV you are programming.
- Press and release the "TV" button on your Universal remote.
- Press and hold the "Setup" button on your remote until the button blinks twice.
- Type in the 5-digit code using the number buttons.
Most likely code for a Samsung TV is 10812
- If the code is correct, you will get 2 blinks. If the code is incorrect, you will get one long blink.
- Use the Universal remote to operate your TV (use Power, VOL, etc..)
12/14/2014 1:51:35 AM •
Samsung...
Answered
on Dec 14, 2014
Samsung le26a6 will not switch on
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
If blinks continue without any pause, the main board is faulty.
