20 Most Recent
Samsung PN50C450B1DXZA 50-inch Class Television 720p Plasma HDTV Questions & Answers
Plasma TV with thin vertical lines
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
9/2/2016 3:00:44 PM •
Samsung...
Answered
on Sep 02, 2016
Fix vertical lines on plasma tv
5/28/2016 10:55:18 AM •
Samsung...
Answered
on May 28, 2016
Samsung overheating and melting frame
BEWARE : STOP USING THIS TV RIGHT NOW AND CALL CUSTOMER SERVICE ENGINEER. IT MAY BE A SERIOUS PROBLEM IGNORING WHICH MAY BE HAZARDOUS TO YOU. TURN THE TV OFF, SWITCH IT OFF FROM THE WALL SOCKET (MAINS) AND UNPLUG IT FROM THE SOCKET. CONTACT SERVICE ENGINEER AS SOON AS POSSIBLE.
8/18/2014 1:24:15 AM •
Samsung...
Answered
on Aug 18, 2014
Vertical lines in the scree of my 50
Several possible reasons include:A bad board somewhere in the set.A communication or Handshake issue--the boards communicate info to the main board and if not proper certain areas of the screen will have lines etc.A power supply issue is rare for this but possible.Last but not least the issue could be a defective PDP---Plasma Display Panel (entire front screen unit) which if is the problem is fatal from a cost point of view.Not likely any of these are going to be either a do it yourself repair or be repaired in the home.
5/3/2012 2:03:47 PM •
Samsung...
Answered
on May 03, 2012
