20 Most Recent Dyson DC14 All floors Bagless Upright Cyclonic Vacuum Questions & Answers
My older dyson is so hard to push, was told there's a kluge to fix it. Where can I find that information?
You will be surprised how much friction dirt on the sole plate will cause, it has to be as clean as possible to glide across the carpet so definitely clean that before you move onto any other solutions, or it's damaged or simply a worn soleplate. hope this helps.
1/3/2018 2:37:02 PM • Dyson DC14 All... • Answered on Jan 03, 2018
The roller on the bottom of my Dyson is not
your machine needs a new clutch assembly cost 29
8/24/2017 2:01:42 AM • Dyson DC14 All... • Answered on Aug 24, 2017
My dyson vacuum will not start
Hello, this is Ava with Think Crucial. If your vacuum doesn't turn on, make sure that plug is fully inserted into a fully functional electronic outlet. If it still not turning on after verifying this, it could be that the power switch is malfunctioning. You may need to replace the power switch by opening up the handle of your vacuum. I suggest to refer to your manual on how to replace the power cord or contact Dyson for troubleshooting steps. 1-844-679-1647 You can purchase a wide variety of high quality Dyson replacement parts for your Dyson Vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10 https://www.thinkcrucial.com/search?type=product&q=dyson I hope this was helpful. Ava B. Think Crucial Customer Care http://www.thinkcrucial.com/
3/12/2017 3:48:17 PM • Dyson DC14 All... • Answered on Mar 12, 2017
Is there a rubber washer under the bin
Hi there, it's Allan at Dyson. There is a black rubber seal on the inside of the bin but nothing beneath it (outside of the bin). I hope this helps but if you have any other questions, please feel free to give the Dyson Helpline a call on 1-866-693-9766 (US), 1-877-397-6622 (CA), 0800 298 0298 (UK). All the best, Allan
2/1/2016 1:17:48 PM • Dyson DC14 All... • Answered on Feb 01, 2016
Where do you put attachments to make them work?
There is a button on the handle that releases the suction tube from the floor brush housing. Once the suction tube is released from the brush assembly, you can install the attachments on the suction tube.
11/15/2015 6:34:50 AM • Dyson DC14 All... • Answered on Nov 15, 2015
How to clean a dyson dc04 all filters?
The manual for the DC04 is here: ( https://www.dyson.co.uk/medialibrary/Files/Dyson/Support/downloads/UK/floorcare/Manuals/dc04_uk_manual_std_120710%20pdf.pdf ). It covers washing the pre-motor filter on top. This Youtube video goes over getting at both of the filters: Replacing the filters on Dyson DC04 upright cleaner Video Dailymotion Good Luck!
11/4/2015 8:20:30 PM • Dyson DC14 All... • Answered on Nov 04, 2015
Dyson wand, handle and hose are all unattached. How do I put them back together?
You can find a copy of the DC14 Manual here ( https://www.dyson.com/medialibrary/Files/Dyson/Support/downloads/US/Floorcare/manuals/dc14_opmanual_usa2007%20pdf.pdf ) Pages 4, 5, and 6 have plenty of schematics for putting the wand/handle assembly back together and getting everything to click. In a nutshell, the metal tube pretty much just slides back into the tube top, and then the slid-in tube clicks back into the top of the machine. Good Luck!
11/4/2015 6:21:19 PM • Dyson DC14 All... • Answered on Nov 04, 2015
Can you blow up an air mattress or air pillow with a Dyson DC14.
no there is only suction on any dyson
9/1/2015 12:31:20 PM • Dyson DC14 All... • Answered on Sep 01, 2015
What model is 171-UK-A61218
Hi there, it's Jack at Dyson. From the serial number you've provided, I can see you have a DC14 All Floors. I'm not sure if you need any help with your machine, but if you do you're welcome to give the Dyson UK Helpline a call on 0800 298 0298. We're available from 8am-8pm from Monday to Friday, and 8am-6pm on weekends. Calls are free from UK landlines.
3/2/2015 12:48:51 PM • Dyson DC14 All... • Answered on Mar 02, 2015
My vacuum cleaner will not stay on
It may need a new switch. If it runs for a while and shuts off it maybe overheating and need new filters.
2/25/2015 11:23:48 PM • Dyson DC14 All... • Answered on Feb 25, 2015
How do I get in to the brush head to replace short hose which is damaged
You can remove the hose by turning the vacuum upside down. You do not need to get into the nozzle assembly
2/24/2015 3:56:20 AM • Dyson DC14 All... • Answered on Feb 24, 2015
Dyson dc14 Animal motor brush replacement
By the time the brushes are shot, so is the armature. You need a motor.
12/30/2014 10:29:15 PM • Dyson DC14 All... • Answered on Dec 30, 2014
Disassembling
YOU DO NOT WANT TO DISASSEMBLE THESE UNITS!! Especially if it's under warranty! They require special tools for assembly and disassembly.
12/26/2014 1:05:46 AM • Dyson DC14 All... • Answered on Dec 26, 2014
Dc33 clutch repair
here you go with clutch with instructions Dyson clutch belt assembly for DC07 amp DC14 900252 04 473
11/26/2014 11:14:46 AM • Dyson DC14 All... • Answered on Nov 26, 2014
How to fix a stuck Dyson dc25 power button
this video should help Dyson DC17 Switch 910971 01
11/26/2014 11:12:16 AM • Dyson DC14 All... • Answered on Nov 26, 2014
2answers
All belts are good but brush will not turn
Hi Nabil, it's Jack at Dyson.If you have a DC14 and the brush bar isn't rotating, it's worth checking to make sure the brush control on the cleaner head is set to 'Carpets', and not 'Hard floors'.http://www.dyson.co.uk/support/dc14/dc14-all-floors/my-machine-is-not-working/i-can-see-something-wrong-visual/i-can-see-something-wrong-visual/my-brushbar-is-not-rotating2/does-the-brushbar-turn-with-the-power-onTip: The brush bar will never rotate when the machine is standing upright, so make sure you recline it down into the normal vacuuming position before testing it.If you're confident the brush control is set correctly, but the brush bar still won't rotate when the vacuum is reclined, please get in touch directly so we can help further. You can reach our experts by calling 0800 298 0298 (UK), 1-866-693-9766 (US), or 1-877-397-6622 (CA).Best wishes,JackDyson Online Customer Supportwww.dyson.com
11/26/2014 11:04:51 AM • Dyson DC14 All... • Answered on Nov 26, 2014
We just installed new plush
I'm sorry to hear you're having difficulties using your DC14 on this particular carpet. We'd strongly advise contacting your carpet manufacturer to check it's suitable for cleaning with a vacuum cleaner equipped with a revolving brush. Manufacturers sometimes recommend cleaning certain types of plush-pile carpeting using suction only.
If you have any further queries about using or maintaining your Dyson vacuum cleaner, please get in touch with us directly. One of our experts will be happy to provide the information and assistance you need. You can call us free on 08002980298 (UK), or 1866MYDYSON (US).
Kind regards,
Jack
11/19/2014 2:00:37 PM • Dyson DC14 All... • Answered on Nov 19, 2014
Dyson DC14 All floors Bagless Upright Cyclonic Vacuum Logo
288 questions posted
Top Dyson Vacuums Experts
AskDyson
AskDyson
Sean Wright
Sean Wright
xxxxxx xxx
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
View Most Popular
Dyson Vacuums
  • Dyson Vacuums
Most Popular Question
rubber washer under bin
  • Vacuums
