20 Most Recent
Samsung Sam4s ER-5240M Cash Register Questions & Answers
How to fix E00 sequence error
To clear the error code do the following:
Turn key to P mode
Turn power switch off
Hold Subtotal key down
Turn power switch back on (while holding the subtotal key)
Wait for print out
Turn your key back to Reg position.
After you do this it will "Close" the register so you will have to log back on.
Samsung er-5240m electronic cash register key noises
If you are hearing key noises when using your Samsung ER-5240M electronic cash register, there could be a problem with the keypad or the register's internal hardware. Here are a few things you can try to fix the problem:
- Make sure that the keypad is clean and free of any dirt or debris. Sometimes key noises can be caused by foreign objects interfering with the keys' movement.
- Check the keypad's connection to the register to make sure it is secure. If the keypad is loose or not properly connected, it may cause key noises.
- Try resetting the register by unplugging it from the power source and then plugging it back in.
- If the problem persists, there may be an issue with the register's internal hardware. In this case, you may need to seek the assistance of a professional repair service.
Samsung ER 350 E- 1 how do I reset
Desligue a caixa registradora Samsung e desconecte-a. Deixe a m?quina desconectada por pelo menos 15 minutos.
Insira a chave de registro na fechadura do painel de controle e gire-a no sentido hor?rio at? a posi??o "P".
Pressione o bot?o "Subtotal". Conecte o gravador a uma tomada aterrada enquanto pressiona o bot?o "Subtotal".
Deixe o log ligar enquanto pressiona o bot?o "Subtotal". Solte o bot?o depois que o registro for ativado.
Gire a chave de registro no sentido hor?rio para a posi??o "REG". Quando o registro imprime um recibo mostrando a hora e a data, o registro da Samsung ? redefinido.
