20 Most Recent LG 47LV5500 47-Inch 1080p 120Hz LED TV with SmartTV Questions & Answers
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Line faults to all LCD screen are similar, irrespective of its brand and screen size.
LG 47LV5500... | Answered on Feb 26, 2016
Does the screen flash on briefly then go black when first switched on? See my posts in march for my answer to this fault.I traced the same fault on my own tv down to a faulty led in the backlight strip. Also my tv did the same thing,standby light flashed twice and then went out.Hope this helps
LG 47LV5500... | Answered on Mar 26, 2015
Sounds like a bad T-Con board which is the board at the Top-Middle of the set. I have also seen the display bad causing that problem in Lg's. Have it looked at first.
LG 47LV5500... | Answered on Mar 06, 2013
The dvd player is for region 2. If you would like to make it where you can view region 1 dvds please read all the posts on the link below. Pay real close attencion to posts 7,9,10,11,12.
http://www.avforums.com/forums/blu-ray-dvd-player-multiregion-hacks/1287167-lg-dvx550-dvx582h-request-hack.html
You will want to set it to 0 so you can play any region you would like at anytime.
LG Televison &... | Answered 2 days ago
You don't need 'instructions' for the router. You just need the
SSID - mine is Bell 596
and
WPA Passcode mine is 187DFA25
Go to the settings for the television and put your details in. There is often a sticker on the router itself, or it is in the paperwork that came with it.
LG Televison &... | Answered on Dec 03, 2019
just a cold cable out- in and turn on may do the required trick. else, go for the firmware upgrade - a worst case scenario. check for the remote functions too.
If using code search on your GE URC yields something that works
LG Televison &... | Answered on Dec 01, 2019
I know nothing about such things though I have heard modern TVs are more computer than traditional tv and you increasingly need to use the internal menus to tell them what you want them to do, which connectors you need switched on, etc.
LG Televison &... | Answered on Nov 30, 2019
Possibly the replacement main board failed.
Hi Modupeola-
I found this link.
https://www.lg.com/ph/support/support-product/lg-32LD330
Download the owners manual. On page 33, it talks about VESA wall mounting specifications. The 22LD330 26/32LD330,32LD340, 26/32LD331C all use the LSW100B, LSW100BG wall mounting bracket.
Hope this helps.
LG Televison &... | Answered on Nov 29, 2019
Hi William-
I found this link regarding the owners manual.
https://www.lg.com/au/support/support-product/lg-DP132#manuals
I also found this link regarding DVD Hacks LG DP132 Region Code.
https://www.videohelp.com/dvdhacks/lg-dp132/12291
Hope this helps.
Brother i searched for this fuc**n problem for 3 years . And i found the secret to fix this problem
First u need an android smart phone with IR support on it
Then install an app from app store its name Anymote
Then add me or msg me on facebook Cale mero
Or add me on what's app messenger my number
+201228046000
I will tell u what to do step by step
Depends which wireless headphones you have. Most headphones do not use WiFi, they use Bluetooth or 2.4 MHz RF. Usually a wireless headphone set will have a transmitter plus the headphones. The transmitter usually connects to the TV either with the analog L+R ouputs or the stereo headphone jack.
LG Televison &... | Answered on Nov 28, 2019
If you wish to get some details; visit the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Unlock procedure and to override the password lock and to set the device region free procedure of many popular brand TVs and other devices are given. Search the site by type in this key phrase "How to unlock television"; in the search box at the top left of the display window, to get gathered related posts.
LG Televison &... | Answered on Nov 24, 2019
LG 47LV5500 47-Inch 1080p 120Hz LED TV with SmartTV Logo
5 questions posted
Ekse
RONALD CARTER JR
View Most Popular
  • LG Televison & Video
Most Popular Question
lg turns green screen
  • Televison & Video
