20 Most Recent Epson Stylus Photo R300 InkJet Printer Questions & Answers
general error Delete all print jobs and turn the printer off. Remove any foreign objects from inside the printer. After a few minutes%2C turn the printer back on.
Epson Stylus... | Answered on Nov 09, 2019
Have you contacted Epson directly? I had a problem with the R200 some time ago and it was down to the tracking of the CD/DVD tray being out of alignment. Due to cost of the printers now it is not worth paying to get them fixed. Lookout for Epson deals where you can trade in your old R300 for a newer model. I still have my R200 still going strong and an RX858.I am sorry I have no firm advice to fix it direct.Mac#
Epson Stylus... | Answered on Apr 06, 2019
I had the same problem. Restarted the printer. Reinstalled the drivers. Scratched my head ... nothing! then I moved the printer away from the wall - problem solved! I can't say that this will work for you but if everything else is working, as it was and still is on mine then it's worth a try.
What I didn't realsie was that the cd tray comes out of the back of the printer when it's checking the alignment. I had inadvertantly pushed the printer back, too close to the wall. Moved it forward slightly and it's fixed.
Hope that solves it for everyone.
Epson Stylus... | Answered on May 12, 2018
Check to see if you have the printer selected as the default printer. You can select the correct printer by going to the control panel to see if it's showing as default.
Epson Stylus... | Answered on Oct 22, 2017
Printer manufacturers do not want folks to use cartridges that have been refilled and they deliberately design their printers to not work with refills. If you get a generic refill you have to make sure that they have taken measures to counteract what Epson has programmed into their printers.
Chalk up the experience to GREED - they want you to use their grossly over priced inks - that is where they make their money! Check in Google for work a rounds this nonsense.
Epson Stylus... | Answered on Sep 09, 2017
Network printing with a non-networked printer
This model printer has only an USB printer connection andnormally connected to a computer or laptop.
To connect this printer wirelessly to all laptops on your wireless networkthere are a couple of methods.
Connect the printer to a desktop computer and setup the printer as a sharedprinter. Next connect the desktop computer to your wireless router with a LANcable and then configure the wireless laptops to connect to the shared printeron the desktop computer. NOTE - This desktop computer and printer must be on atall times for the wireless laptops to print to the printer.
OTHER METHOD
Connect the printer to an USB print server and connect the print server to thewireless router with a LAN cable. The printer drivers needs to be installed onall the wireless laptops and then the printer port needs to be deleted from theUSB port and a new IP address printer port installed. This IP address will bethe IP address of the print server.
Epson Stylus... | Answered on May 11, 2017
I'm sorry but I read over the manual and couldn't find a 'general error' message listed. Nor, could I find a way to reset the printer so it could print.
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Doc&oid=26322&prodoid=37368458
The documentation for the epson printer is rather detailed though, and it is possible I missed it somewhere, but I would try the above link for more leads that may lead to a solution.
Maybe try to call Epson technical support for more information:
Contact Support
E-mail line_dkblue.gif spacer.gif If you are unable to find an answer on our web site, you can e-mail your question to Epson Technical Support. spacer.gif Epson Service Center line_dkblue.gif spacer.gif For products in warranty, please contact Technical Support. If your product is out of warranty, find a service center. spacer.gif Technical Support line_dkblue.gif spacer.gif United States Phone Number:
(562)276-7282 begin_of_the_skype_highlighting (562)276-7282 end_of_the_skype_highlighting
Hours: Mon.- Fri. spacer.gif 6AM-8PM (PT) Sat. spacer.gif 7AM-4PM (PT) Canada Phone Number:
(905)709-2567 begin_of_the_skype_highlighting (905)709-2567 end_of_the_skype_highlighting Hours: Mon.- Fri. 6AM-8PM (PT) spacer.gif
Epson Stylus... | Answered on Jan 20, 2017
I turned the printer upside down, shook it and tapped the bottom and wehey.......problem sorted!!
Epson Stylus... | Answered on Sep 27, 2016
Epson's ink uses a dift technology so far better result you need to check what brand of glossy or photo paper you can use. You can purchase an epson photo or glossy paper for best results.
Your printer would work best using the list below:
Paper Types
  • Supports a variety of Epson plain and photo papers. Supports plain, bond, air mail, Epson Premium Bright White, Glossy Photo Paper, Premium Glossy Photo Paper, Premium Semigloss Paper, Premium Luster Paper, ColorLife paper, Matte Paper Heavyweight, Double-sided Matte, Inkjet Transparencies, Self-adhesive Sheets, Photo Quality Ink Jet Paper, Greeting Cards, High Quality Banner paper; labels; envelopes, Iron-on Transfers and Photo Stickers; Printable CD-R/DVD-R; Panoramic 8.3" x 23.4" Photo Paper
If you may have other questions pls feel free to ask.
Just rate me Fixya if your issue has been resolved.
Cheers.
Epson Stylus... | Answered on Jun 14, 2016
Start with a "nozzle check" and confirm that all your colors are printing properly. Epson printers are prone to clogging, and this can cause very strange effects if some of the colors don't fire properly. I just replaced my Epson Photo 260 because I couldn't get the black head to clear....
Epson Stylus... | Answered on Mar 02, 2016
Is your Epson printer new? If so you would have got a CD. Why not try the CD. If not you could try any Epson near R300 series. It might work or sometime it may detect by itself and connect your printer to the computer.
Epson Stylus... | Answered on Nov 16, 2015
It is somewhat difficult to give a helpful answer as you do not mention what sort of image files are on the card and that could be the real culprit- If your camera produces RAW image files, then you cannot print from those - you need a format like JPEG of TIFF (as examples). Please give some more information so we can then help.
Epson Stylus... | Answered on Oct 03, 2015
IIf the cartridges is original epson there is some color (light magenta that is clogged.
if the cartridges is non original check that is with the right order
Epson Stylus... | Answered on Apr 24, 2015
Epson Stylus Photo R300 InkJet Printer Logo
788 questions posted
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
Stylus Epson
  • Stylus Epson
Most Popular Question
problem printing yellow
  • Office Equipment & Supplies
