20 Most Recent
Epson Stylus RX500 All-In-One InkJet Printer Questions & Answers
Roller Marks
Try this to clean the rollers:
Put in blank sheets of paper in then print out from microsoft word a blank document.
This should clean the rollers. Also, there might be special cleaning sheets that you can purchase from Epson.
Stripes all over page
one or more of the cartridges will most probably be out of ink, make sure all cartridges contain at least a 3rd of ink and if they do then perform a head clean followed by a nozzle check, if the nozzle check print is not perfect then do another head clean nozzle check & repeat the process until you get a perfect print on the nozzle test pattern.
If that is not the issue then I suspect driver corruption and you will need to un install then re install your printer drivers
