20 Most Recent
Epson TM-U220 Matrix Printer Questions & Answers
Epsom TM-U220 Error Codes
From the manual its probably one of this item.-printer temp is too high-cover is not properly closed-print head is not in the correct position-paper cutter is not in the correct position-paper jamTry turning off the printer, remove the power cable, turn it on again for 5 seconds to reset it. Connect back power cable, press the feed button and turn it back on. The printer should do a self test, turn it off and on again after the self test. It should make the red light go away.
I need driver for printer
You can download the appropriate driver on the following webpage:
https://download.epson-biz.com/modules/pos/index.php?page=prod&pcat=5&pid=42
Receipt printout is smearled
The U220 has a shaft adjustment on each side to adjust the distance from the printhead to the paper through the ribbon. If it is too close, and it can move due to normal function, it will eat ribbons nad smear the text. I recommend taking each one off, bending the end of each one inward to make better contact, setting them straight down, and testing without the covers on. WHen you get a good print, replace covers and test again.
I need to reset my
the ip is 224.0.0.1
when i tried changed my notebook IP, it said invalid range.
Continuous printing without sending
go control panel on the computer , devices , properties and cancel the print list
the machine is probably in a loop and prints the last order instead of clearing it and moving on
TM-U220 printer is not printing anything.
do a self-test first. Perform by holding down the feed button then powering on the printer. if it prints then it is not a printer issue, but a driver or cable issue.
