20 Most Recent
Epson TM-U295 Matrix Printer Questions & Answers
I have epson TM U295
Check that the printer is connected, powered up and has all of the required consumables.
light printing
You need to adjust the print head spacing. This is a lever along the side inside the printer by the print head. It just move the head closer or further away from the paper. The closer it is the harder it strikes the bottom pages and it should print darker on them. If you get it too close it can catch the paper and cause a jam so you have to give it a bit more space. You may end up redoing this if you use a different brand or type of nc form paper. Just open the cover look for a lever on the side and lick it a notch (should show circles so go to the smaller one) and try printing. You might have to waster a few pages before it behaves but this is all you need to do.
Epson TMU-295 prints in condensed
window is not the faulty one if you are using a third party software of sent print option from internet then problem must be with in drivers..... print a self test page if ok then print test page from system (control Panel) if both point ok then there must be problem in online software/ERP.
