20 Most Recent
Epson Premium Compatible** Inkjet Cartridges USA Printer Questions & Answers
Changing the ink with the proper refill and it is
Take a look at my tip on cartridges it may save you a lot of time and money
http://www.fixya.com/support/r3845491-ink_cartridge
OR
Read on and see if any applies to you.
Check that you removed the protective tape. some cartridges have two of these pieces of tape one over the head and possibly on on the contacts to the printer.
If you recently re-filled or had the cartridge refilled or even bought one of the many cheaper replacement cartridges you should read on
Most modern cartridges have an ink level chip built on to them.
Should the level drop below 25% then most of these chips lock up and will not reset.
Re-filling them will have no effect
If you are lucky you should be able to find either a chip resetter around on the INTERNET or maybe even local
OR
Even better empty cartridges that never need to be reset.
The second option is my preference
I realise these are not for your specific printer but there are others listed on both those sites as well.
cheaper cartridge problems have been on the rise recently and that is for ALL makes of printer.
If you try to clean the contacts be VERY careful cleaning contacts and ONLY use isopropynol on a lint free bud or cloth.
Also be very gentle.
I have seen the contacts cleaned and cartridges ruined with other methods of cleaning.
Rubbing too hard can also cause a badly set chip to move making it inoprable.
I dont like full prices replacements either which is why I always provide the links
I usually reccomend that people take back any cartridge that does not work right from the get-go.
I dont know of anyone who has had a problem doing that be it a shop refill or otherwise.
No matter if I paid $1 or $100 for a cartrdige I would still expect it to work
Hope this gives you the information you need
Bob
EXMod
It would be very decent of you to consider the quality of our experts answers and judge them accordingly as you pass through FixYa.
Thank you
Epsom stylus CX4700 won't print - new ink cartridges installed
They cut costs on Epson compatible cartridges by using low quality ink and chips or not resetting the chips at all. Sounds like you got cartridges that the chips were not reset on so your printer thinks all the cartridges are empty. I own a Cartridge World ink refilling store and I would never recommend purchasing compatible Epson cartridges from anyone. I would buy refills of Epson brand cartridges and make sure the seller reset the chips.
Epson lq-690II printer reflects the paper when printing
Troubleshooting Paper Reversal in Printers:
*Confirm that options related to paper handling are set correctly by checking for specific buttons or switches that relate to paper handling or reversing.
*Ensure that paper is loaded properly to avoid feeding problems.
*Remove any dust, particles, or paper remnants from the rollers, as they can impede paper flow.
*If other measures fail, reset the printer to its initial settings to resolve potential software glitches.
EPSON 15140 error 034019
Try a hard reset of the printer. Oddly, the 034019 is not an error code, I have reason to think. It is a contact number, I believe.
Reset my Epson printer L382
Follow the steps given below to reset Epson L382 printer.
Step 1: Turn the printer off.
Step 2: Press and hold the reset button which is on the back of the printer using a paper clip or tip of a pen.
Step 3: Turn on the printer by holding the Power & reset button and continue to hold both the buttons.
Step 4: Wait for 5 seconds and a warning sheet will print. Release the reset button.
Step 5: After 5 seconds, another sheet will print which will show the IP address of the printer.
WHERE IS RESET BUTON? I CANT FIND IT.
I have Epson printer workforce pro c5790 shows error 000101, what is the solution for it ?
The error code 000101 on an Epson Workforce Pro C5790 printer typically indicates a problem with the print head.
Here are some steps you can try to troubleshoot and fix the issue:
- Perform a print head cleaning: From the printer's control panel, navigate to the Maintenance menu and select the option to perform a print head cleaning. This will help to clear any clogged nozzles or debris that may be causing the error.
- Perform a print head alignment: From the printer's control panel, navigate to the Maintenance menu and select the option to perform a print head alignment. This will help to ensure that the print head is properly aligned and is able to print correctly.
- Check for any physical obstructions or debris in the print head area, if you find any, remove it carefully.
- If the error persists after trying the above steps, you may need to replace the print head.
- If none of the above steps work, it is possible that the printer has a more serious problem that requires professional service.
I recommend you to check the user manual or contact Epson technical support for further assistance and specific troubleshooting steps for your printer.
