20 Most Recent Sony Grand Wega Kdf-46e2000 46-inch 3lcd Rear Projection Television Questions & Answers
Good day!!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Sony Grand Wega... | Answered on Oct 17, 2012
Could be the motherboard, or a fuse. Without having it in hand it is hard to tell what it is. Check to see if there is an inside fuse in it.
Sony Televison &... | Answered 3 days ago
That is because it is a DVD controller, not a TV controller.
Sony Televison &... | Answered on Dec 05, 2019
You will find it if you google it.
Sony Televison &... | Answered on Dec 01, 2019
6 red flashes- backlight issue, bad main board, or power board or inverter boards- check standby volts on power board. "backlight on" volts should be 3-5v from main logic board then 24v to inverter.
2 red flashes is bad power board, solution replace power board or repair it.
Possibly tv reach its end. Save money and replace it with modern energy efficient tv.
Unless your Sony remote control is programmable, you are unlikely to be able to find a code for your Sansui TV.
Sony Televison &... | Answered on Nov 27, 2019
Use code search on your GE URC to find something that works. If a search through all codes contained in the URC fails, try a different one.
Hi Daya,
It is a panel fault. It can be repaired. But it is a tricky and risky job. To attempt this repair you need to be an experienced technician. If you are a technician, please let me know. I will give you the details.
Sony Televison &... | Answered on Nov 23, 2019
Whats the model of the TV?
Thanks
Or something is overheating You can try updateing your software. But if that doesnt work I would take it to a repair shop.
Sony Televison &... | Answered on Nov 21, 2019
Sony Grand Wega Kdf-46e2000 46-inch 3lcd Rear Projection Television Logo
7 questions posted
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Televison & Video
Most Popular Question
poewr shotoff every 2minits
  • Televison & Video
