20 Most Recent Konica Minolta Bizhub C 6500 Copier Questions & Answers
How to clear the code C-2451on a konica minolta
Check yellow developer unit and might need to replace it or replace the developer
4/3/2020 9:52:56 PM • Konica Minolta... • Answered on Apr 03, 2020
Error code 3501
HI I HAVE KONICA C6500 ERROR CODE 3501 and 3802 but know the error 3501 I know it rech high temperature I change the sensor 1 UP fuser roller and I reset the error, the machine start and stop again with error 3501
1/12/2017 7:07:44 PM • Konica Minolta... • Answered on Jan 12, 2017
Bizhub c6500 error code C-3913
Check the fusing position, check all connector, make sure everything oke, and doing this adjustment: Utility => Stop => 0 => Stop => 0 => 0 => 1. This is to prevent accidental reset of the code and causing additional damage to the machine. To reset a fuser abnormality code, perform the following: 1. Power the machine OFF from the main switch leaving the sub switch ON. 2. Press the utility Key and power ON the machine from the main switch. 3. Enter Stop => 0 => 0 => Stop => 0 => 1. 4. Press [03 System Setting] on the touchscreen. 5. Press [01 Software SW setting] on the touchscreen. 6. Press the left up-arrow, which is displayed on the touchscreen, 2 times. The number displayed above the up-arrow will change to 03. 7. Select the bit number of switch 1, using the right up-arrow, 03-1 will be indicated. 8. Press the [Return] key, which is displayed on the touchscreen.
12/22/2016 12:39:48 AM • Konica Minolta... • Answered on Dec 22, 2016
Error code 3904
replace the fusing unit and have a tech look at it Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
7/4/2016 5:12:27 AM • Konica Minolta... • Answered on Jul 04, 2016
C0315
There is a fan in that draw that helps feed the paper by blowing on it check that fan burned out, dirty, jammed???????? Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
1/18/2016 4:00:27 AM • Konica Minolta... • Answered on Jan 18, 2016
C6500 prints darker on one side
so this is a duplex issue???? Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
1/10/2016 5:11:26 AM • Konica Minolta... • Answered on Jan 10, 2016
Konica minolta 6501 screen freezes
have tech come re-flash the firmware check connection of the control panel Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
12/30/2015 5:41:54 AM • Konica Minolta... • Answered on Dec 30, 2015
How do I add developers to the machine -I would need the steps to do this - I have the steps for Coronas and drums but not how to change developers
It is quite a lot to write down, recommended a service tech do it. try this site they mite have the service manual Service manuals electronic components datasheets and equipment schematics... Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
11/19/2015 1:11:02 AM • Konica Minolta... • Answered on Nov 19, 2015
C-2454
Sir /Mam the Black developing unit has it had its developer replaced if not needs to be also it could be that the Developing unit need replacing or the ATDC sensor located inside the developing unit is bad did the person who replace the Black developer recently use a vacuum cleaner to remove the old developer if so he or she destroyed the sensor never ever use a vacuum clearer to remove old developer the static electricity form the vacuum cleaner destroys the sensor. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
8/9/2015 4:26:04 PM • Konica Minolta... • Answered on Aug 09, 2015
Reset error code 3102 on Konica Minolta bizhub 6500
drive issue for the fusing motor, get a technician to look at it Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
5/25/2015 9:31:00 PM • Konica Minolta... • Answered on May 25, 2015
How can i do for error C6702
http://www.copytechnet.com/forums/konica-minolta/30879-konica-minolta-biz500-code-error-c-6702-a.html guy does eventualy fix it on later pages worth a good read i got board half way down a good tip with rollers {rubber not sponge} is too use white vinegar wipe it on leave it to dry and run few some fully black sheets...prints then it works magic
12/9/2014 10:15:51 PM • Konica Minolta... • Answered on Dec 09, 2014
0answers
0answers
0answers
0answers
0answers
C-2470
Be the first to answer 2/27/2013 3:01:51 AM • Konica Minolta... • Posted on Feb 27, 2013Be the first to answer
0answers
Konica Minolta Bizhub C 6500 Copier Logo
28 questions posted
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Konica Minolta Office Equipment & Supplies
Most Popular Question
c 2454
  • Office Equipment & Supplies
