20 Most Recent Dell Inspiron 9100 Notebook Questions & Answers
13answers
Laptop screen has horizontal white lines running across half the screen
Horizontal lines on bottom third of my Toshiba (Satellite Pro) Laptop with XP windows got fixed by flicking my finger on the laptop screen! Was it a loose connection? I don't know. Change of screen resolution did not help, Rebooting, did not help nor restoring to prior dates. Thank you guys.
8/29/2019 12:28:54 PM • Dell Inspiron... • Answered on Aug 29, 2019
How do I get rid of gray line upper thirds on my tablet screen?
Sounds like back-light fault. Contact any service center. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter". http://electronicshelponline.blogspot.com/
6/23/2014 2:53:25 AM • Dell Inspiron... • Answered on Jun 23, 2014
0answers
0answers
0answers
Battery Error Code:2000-0133
This error code shows that the battery has got completely damaged or about to damage. the last thing, if you are using a duplicate battery, or no battery in system, then also it can show you the same error. You need a new original battery for your system.
10/15/2013 6:33:23 AM • Dell Inspiron... • Answered on Oct 15, 2013
0answers
I have white rectangle on the middle on screen how
Connect the vga cable of external monitor and check if the sameproblem occurring., then issue with motherboard if problem not coming thenissue would be lcd screen .
9/11/2013 4:34:44 AM • Dell Inspiron... • Answered on Sep 11, 2013
0answers
Dell inspiron mini 910 laptop video has lines and text is hard to read
1) Is the Screen resolution set correctly?Native screen resolution should be set to 1024 x 600.Right-click on an empty area of your desktop screen.Go to the bottom of the list, and click on - PropertiesThe Display Properties window will come up.Click on the Settings tab.Down in the middle of the Display Properties window, you will see Screen resolution in blue.There is a Slider. In WinXP it is an Arrow, with a Green tip on top, and bottom.Left-click on the Slider, hold the left mouse button down.Now move your mouse to the Left, to drag the Slider to Less screen Resolution, or to the Right to Increase.Stop at 1024 x 600 pixels.Also the Color quality should be set to Highest (32 bit)Click on the blue down arrow to the right of the Color quality box.In the list click on Highest (32 bit)Go below to the Right, and click on Apply.Now go below to the Left, and click on OK.If that doesn't cure the problem, the problem is a hardware issue.Problem will be;1) Graphics chipset,OR,2) Video Cable,OR,3) LCD screen[The Backlight used is LED backlighting. Uses a series of LED's.Light Emitting Diode.There is NO screen Inverter ]http://www.dell.com/support/Manuals/us/en/19/Product/inspiron-mini9If it is a hardware issue, I can guide you through the diagnostic flowchart, to see what the problem is, and step by step.Post back in a Comment.Regards,joecoolvette
3/16/2013 8:40:49 PM • Dell Inspiron... • Answered on Mar 16, 2013
Vertical black bars screen
Try connecting an external monitor to the 15 VGA (video) plug on the laptop and see if it displays properly on the monitor. You may have to direct the video from the laptop to the monitor by holding down the blue <FN> (key next to the space bar) and then press down the <F8> key.If the display on the external monitor is correct, then you either have a problem with the laptop's LED display screen or cable that connects the LED to system board. Here is a link for the service manual:ftp://ftp.dell.com/Manuals/all-products/esuprt_laptop/esuprt_inspiron_laptop/inspiron-9300_service%20manual_en-us.pdf
2/17/2013 1:06:56 AM • Dell Inspiron... • Answered on Feb 17, 2013
Quand j'allumé mon dell mini 910
12/19/2012 12:34:45 PM • Dell Inspiron... • Answered on Dec 19, 2012
0answers
Dell Inspiron 9100 Notebook Logo
128 questions posted
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
View Most Popular
Inspiron Dell
  • Inspiron Dell
Most Popular Question
laptop screen horizontal white lines
  • Computers & Internet
