20 Most Recent Dell PowerEdge 6650 Server Questions & Answers
tengo um problema con mi servider me pude insertar 2 discos pero como utiliso la relif para este servidor
Dell PowerEdge... | Answered on Nov 13, 2013
Hello here is a link to the homepage:
http://search.dell.com/results.aspx?cat=sup&s=gen&c=us&l=en&cs=&k=replace+CMOS+battery
And here is the download site for drivers:
http://www.dell.com/support/drivers/us/en/19/Product/poweredge-xeo6650
Try also to upgrade the bios. just make sure its the right model.
You maybe have to set up the boot settings when you replace the cmos battery or renew the bios.
Good luck
Dell PowerEdge... | Answered on Nov 07, 2012
Sounds like a bad motherboard have you check it for blown caps?
Dell PowerEdge... | Answered on Mar 07, 2011
Not sure what the beeping sound is but if it is an error code beep, go into your BIOS at startup and disable audiable alarm for boot errors.
Good Luck
C2S
Dell PowerEdge... | Answered on Jul 12, 2010
Write down service tag and express service code from server label.
Call Dell. PowerEdge servers come with lifetime phone support.
I think the number is: (800) 945-3355
If this helps, please vote for my solution.
Dell PowerEdge... | Answered on Oct 16, 2009
Have you checked boot device options....from BIOS
Use F9 during boot to goto ROM-BIOS and change Boot device option to CDROM/DVDROM.
Insert Boot media or DVD-Win2003, to DVD-ROM device..
reboot Server, try now
If still issue.. Check to boot Server using some other media..
if other cd media works, then it could be DVD-Win2003 faulty, otherwise download firmware for CD/DVDROM and upgrade it and check if DVDROM works, otherwise you have to contact Dell Support..
Dell PowerEdge... | Answered on Oct 10, 2009
Computer not recognizing the hard drive. Look in BIOS to see if hard drive is listed. Reload system disc/CD.
Dell PowerEdge... | Answered on Mar 14, 2016
It could be a couple of things 1. the computer Cpu fan is not working or is clogged inspect it and clean or replace.2 The power supply could be bad
Dell PowerEdge... | Answered on Jun 14, 2015
Namrata_stha,
The I912 error is referring to the System Event Log is full of events and because of this is unable to log anymore. You must clear the log in order for the Server Management controller to log any more events. Now depending on the OS installed there are different ways to clear it. If Windows Server 2k8 you would use this command - wevtutil el ' foreach { wevtutil cl $_ }
Where with Server 2003 you can go tot he Event viewer and clear it.
Let me know if this helps.
Dell PowerEdge... | Answered on Oct 01, 2014
www.hp.com/support
Dell PowerEdge... | Answered on Aug 18, 2014
Please be more specific. You haven't actually asked a question. What are you trying to do? What happens that you aren't expecting?
Dell PowerEdge... | Answered on Aug 08, 2014
You will have to get into the controlled setup in order to find out what the problem is, or you can simply hit ctrl-D and do the Dell disk diagnostics which will take an hour or more, but will give you an idea of where to start.
Logically, if it won't boot, then your RAID is probably broken. it can sometimes be repaired through either the RAID or controller setup menu, which you can see during boot.
go here, for the manuals and documentation on how to do that: http://www.dell.com/support/home/us/en/19/product-support/product/poweredge-t105/manuals
Dell PowerEdge... | Answered on Jun 04, 2014
what is your server model? in most cases you can use the operating disc to format the server drives
Dell PowerEdge... | Answered on Apr 04, 2014
Go to start menu. click on 'control panel'. Select 'system and security". Then select 'system'. This should give you the info.
Dell PowerEdge... | Answered on Mar 27, 2014
Dell PowerEdge 6650 Server Logo
9 questions posted
Ekse
Clive
Clive
Alun Cox
View Most Popular
PowerEdge Dell
  • PowerEdge Dell
Most Popular Question
describe poweredge 6650 driver failed ps
  • Computers & Internet
