20 Most Recent Dell PowerEdge 1600SC Server Questions & Answers
Hi i have connected a floppy disk drive to my Dell
Not sure what "the drive forks" actually means. The floppy drive usually connects via a dedicated connector on the motherboard by a ribbon cable similar to the IDE cables but physically smaller and of course to the power supply. If the drive, the cable and the motherboard is ok it should appear in the bios list ready to be enabled and added to the boot order. If the floppy drive doesn't appear in the list you should refer to the motherboard manual as there might be some jumpers to reset or perhaps it is only suitable for a usb floppy drive. Take the number from the motherboard and do an internet search which should direct you to a place where you can download a manual which will contain all the information you need.
11/11/2017 2:06:20 AM • Dell PowerEdge... • Answered on Nov 11, 2017
Cloned Drive won't boot on Dell 1600SC
If you are using an image made from the IBM and it has a different processor and the board specs are different that can cause the drive not to boot it will act like it is then go into a perpetual boot. I would try to re image it again to insure that is ok on the drive also check the board If one is and AMD and the other an Intel then that would be part of the problem.
11/2/2017 9:41:41 PM • Dell PowerEdge... • Answered on Nov 02, 2017
How to open front panel of Dell Poweredge 1950 without key
Get creative. This is not a tech support question. This should be considered as "Closed."
6/13/2015 10:33:58 PM • Dell PowerEdge... • Answered on Jun 13, 2015
2answers
How to open front panel of Dell Poweredge 1600Sc without key
The lock on the Powerledge is not too difficult to pick. A home made pick or buy a small lock picking tool set (less than $20). Without any training you can pick it in five minutes.
8/13/2014 1:51:13 AM • Dell PowerEdge... • Answered on Aug 13, 2014
Display drivers for win server 2008 32-bit sp 1
Go to Microsoft for drivers.
3/19/2014 11:24:14 PM • Dell PowerEdge... • Answered on Mar 19, 2014
0answers
Scsi controller devices
Yes Doug. What is your problem with your Scsi controller device?
2/1/2014 4:29:32 PM • Dell PowerEdge... • Answered on Feb 01, 2014
My raid 3 controller has failed on my dell P/edge 1600sc how do i repair same
Get a new one, you can not repair them.
1/29/2014 1:08:21 AM • Dell PowerEdge... • Answered on Jan 29, 2014
Dell poweredge 1600sc w/ ATI Mach64 w/ Windows 7 Ultimate highest video mode is 24 bit true color
Bios too old and the 32 Bit system is inadequate to manage the function desired.
1/29/2014 12:32:53 AM • Dell PowerEdge... • Answered on Jan 29, 2014
Hi. I Inherited a DELL Poweredge 1600SC server.
the screen rem... ??
12/19/2013 9:02:40 AM • Dell PowerEdge... • Answered on Dec 19, 2013
We have an old Dell PowerEdge SC430 that beeps
It seems to be DRAM refresh error. Kindly unplug the RAM and plug it back.Regards,Kaushik Patel
11/7/2013 8:49:02 PM • Dell PowerEdge... • Answered on Nov 07, 2013
I guess you can't go into start button. /anyway how did you know if computing is powered? On your keyboard top line keys have screen control keys for brightness etc.eg f4. try.
8/3/2013 11:07:12 PM • Dell PowerEdge... • Answered on Aug 03, 2013
How to reset BIOS?
You can do that by doing the jumper settings procedure, you can find the steps from the user manual of your unit
4/7/2013 5:02:07 AM • Dell PowerEdge... • Answered on Apr 07, 2013
Fan error reported
Re-seat it, If still failed, replace it.
3/28/2013 11:32:35 PM • Dell PowerEdge... • Answered on Mar 28, 2013
Factory Reset
create a wipe disc from the internet or just install OS, When new OS is installing, before it does it automatically formats the hdd
1/25/2013 12:11:07 PM • Dell PowerEdge... • Answered on Jan 25, 2013
0answers
A power outage cause dell server 1600sc to shut down & no display on the monitor
Hello here is the homepage.http://www.dell.com/support/drivers/us/en/ussoho1/Product/poweredge-1600scThere should at least be a message on the monitor indicating there is no signal coming to the monitor. The first thought that comes to mind if all is connected would be that the power supply has failed. And maybe the graphic card.Call also the DELL support in your country they will be glad to helpand they probably know the fault. Contact Us 1-877-671-3355Good luck
11/26/2012 4:40:02 PM • Dell PowerEdge... • Answered on Nov 26, 2012
Dell PowerEdge 1600SC Server Logo
117 questions posted
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
View Most Popular
PowerEdge Dell
  • PowerEdge Dell
Most Popular Question
server show system memory
  • Computers & Internet
