20 Most Recent
Dell POWEREDGE 2400 Server Questions & Answers
It doesnt reconize my cd rom at boot and is not
Enter the set up (BIOS) menu by tapping the F2 key. Hold down the <Alt> key and depress the <E> then the <F> keys in succession. This will force the motherboard to load default settings and also force the motherboard to redetect all IDE devices. Note: The selection for the floppy drive will be set to ON. If you do not have one then you must disable floppy in set up (BIOS) menu.
I am try to do
Please elaborate on your problem.
If you are trying to install from USB, you first have to enable the USB in the BIOS.
Older models of Dell PowerEdge servers does not support the USB function. It is all dependent on the mother board.
Dell PowerEdge 2400
I have one for sale at
www.JonRosenSystems.com. This is an extremely large and heavy unit. It has two P3-733 CPU's, 512mb RAM and three 18gb Quantum Atlas SCSI drives. I have more drives and RAM available.
Beeping Upon Bootup
dependent on how many beeps you hear is dependent on what might be the problem.
A fuller explanation from pushing the power button to nothing happening would be more than helpful.
Beeps in a Poweredge can mean motherboard, memory or as you said power supply problems.
Power is 2950 i912 sel full
Namrata_stha,
The I912 error is referring to the System Event Log is full of events and because of this is unable to log anymore. You must clear the log in order for the Server Management controller to log any more events. Now depending on the OS installed there are different ways to clear it. If Windows Server 2k8 you would use this command - wevtutil el ' foreach { wevtutil cl $_ }
Where with Server 2003 you can go tot he Event viewer and clear it.
Let me know if this helps.
STRIKE f1 ERROR
Please be more specific. You haven't actually asked a question. What are you trying to do? What happens that you aren't expecting?
Format disk
what is your server model? in most cases you can use the operating disc to format the server drives
