20 Most Recent
Belling 23 in. GHU567 Gas Cooktop Questions & Answers
Belling Induction hob flashing E6
An E6 error code on a Belling induction hob typically indicates an issue with the power supply or the circuit board that controls the back two rings. Here are a few steps you can take to troubleshoot the issue:
- Reset the hob: Try turning off the power to the hob for a few minutes and then turning it back on. This can sometimes reset the circuit board and clear the error code.
- Check the power supply: Make sure the hob is receiving a stable and adequate power supply. Check the circuit breaker or fuse for the hob to ensure it is not tripped or blown.
- Check the wiring: Inspect the wiring and connections for the back two rings to ensure they are not loose or damaged. Tighten any loose connections or replace any damaged wiring.
- Contact a professional: If the issue persists, it may be a problem with the circuit board or control module. In this case, it's best to contact a professional technician or the manufacturer for assistance with repairs or replacement parts.
I hope this helps you resolve the issue with your Belling induction
Replacing faulty regulator for hotplate
Remove hotplate and oven control knobs. Under the 2nd and 5th knobs is an extra screw which holds on the front cover. Unscrew these and free the cover then access is gained to the screws (2 on each edge) which removes the plate to which the regulators are fixed.Remove the faulty regulator by unscrewing it from the plate,(2 screws) It is an easy job then to install the new part taking care to put the correct wires on the correct terminals. Reassemble, job done!
I can't lower the heat on my Whirlpool electric stove cooktop. Started about a month ago. Stove is 15 yrs old. Everything else on the stove works e
It needs a new control if it has dials or a control pad or a part if it is electronic. Full make and MODEL (what it is) in all answer please as first 3 words in every question.Edited as model number given Whirlpool GFE471LVShttps://www.whirlpool.com/owners-center-pdp.GFE471LVS.htmlThe Infinite Switches are $130, so it is best to test them with a multimeter first.https://www.partswarehouse.com/Whirlpool-GFE471LVS0-Freestanding-Electric-Range-s/131742.htmVideos showing how to changehttps://www.google.com/search?q=whirlpool+gfe471lvs+replace+hob+infinite+switchOwner Manual, just because it was therehttps://www.manualslib.com/products/Whirlpool-Gfe471lvs0-10479409.html..
4/6/2024 6:50:10 PM •
Cooktops
Answered
on Apr 06, 2024
