20 Most Recent
Tektronix Phaser 350 - 600 x 300 dpi - 24 MB - up to 6 ppm - No Ink/Toner Questions & Answers
Printer error code 61 on
Hello Sancorp,
In order to provide you a better solution I request you to provide me the opearating system you are using and also the make of the computer.
Thank you.
I have a Tektronix Phaser
This is from the 560 manual hope the codes are the
same. The 560 manual states : Accumulator belt cleaning blade movement
error.
1. inspect the cleaning blade{located on the imaging unit,along
the bottom of the green OPC belt. Is it flipped up? If you cannot flip
it down, replace the imaging unit.
2. Inspect the wiring harness
leading from the cleaning board to CN18 of the engine control board.
3. Replace the cleaning board.
4. Replace the engine control board.
If the above info does not match your model call :
(800) 833-9200 Press 3
(503) 627-2400
