20 Most Recent Dell Dimension 2400 PC Desktop Questions & Answers
codec are basicaly needed to watch andy videos or music files....
get FFDSHOW codec from google, it's the best
Dell Dimension... | Answered on Nov 13, 2019
Make sure u can open the casing well to expose the interior parts without causing any damage. Then by close look at the processor area , that is where the heat sink is located. Normally the dell dimension 2400 has a green channel shaped structure that acts as a passage for the air that enters in and out for cooling the heat sink. It has a locking parts that slides into the casing back by slight pressing to the back of the casing just behind the processor area, be so observant to notice the locking parts. then the fan is just fixed behind that green " channel like" and its fixed on the rear side of the casing, 25275582-o0cuhlgwrl13okm3u3q5444d-5-0.jpg
Dell Dimension... | Answered on May 03, 2019
the mail problem with those dells is the video card was not very good. you can go to dell and put in the tag number and download the drivers for it and that might help. the old dell was a xp machine and it might be the only drivers you can get for that. if you have upgraded to windows 7 there are not drivers for that in w7
Dell Dimension... | Answered on Sep 17, 2018
Try to uninstall and reinstall the display drivers. For the desktop icons, right click desktop->Arrange icons by->show desktop icons.
Dell Dimension... | Answered on Aug 06, 2018
time to replace it sad to say
Dell Dimension... | Answered on Jul 02, 2018
check your parental settings - log in as administrator and turn off parental settings. this should solve the problem on a windows 7 machine.
it means that the monitor is not receiving any signal from the cpu, check the cable that goes from the tower (cpu) to the monitor
Dell Dimension... | Answered on Jun 30, 2018
you got drivers on dvd. find the dvd, and usually it's the one with dell logo. you have to install Drivers from that and your dell will Fly. You have to install: graphic card dvd, dell dvd, and audio drivers. also, check in control panel/system/hardware  if in front of system components there's a ? mark or !. install those things.
Dell Dimension... | Answered on Jan 30, 2018
Hi, just use the steam service online they are very reliable, www.store.steampowered.com
Dell Dimension... | Answered on Jan 09, 2018
Here's the Microsoft Page for using Movie Maker on XP,
http://www.microsoft.com/windowsxp/using/moviemaker/default.mspx
and here's the Download Site for Movie Maker XP,
http://www.microsoft.com/windowsxp/downloads/updates/moviemaker2.mspx
It's installed through Windows Update normally so you should just install every Windows XP Update available. Go to the Start Button>All Programs> Windows Update and click on it. Follow all the prompts and say yes or ok to everything.
Good Luck
Dell Dimension... | Answered on Dec 30, 2017
The last guest left us hanging with, "easy fix" so, I ventured ahead to see what I could see by opening up my lcd, which was a puzzle in itself. After UNPLUGGING the monitor and removing the stand and the 4 obvious screws in the back, turn the monitor onto its back and placing your palms against one side of the monitor, and using your FINGER TIPS, gently pull back the plastic lip away from the LCD screen. Move along the lip, doing this a little bit at a time. You'll hear and feel it snap loose. Repeat on the remaining three sides. It may take a few rotations to free all the sides, doing a little at a time, so as not to put undo stress on the plastic that is not yet loose. The bottom lip from behind which lies the offending "on/off" button will not move as freely as the other sides because of the ribbon cord that attaches the circuit panel to the main body. So STOP pulling when you feel it become taught and carefully turn the monitor onto its face to complete the face's removal. Undo the cloth tape that secures the ribbon cable to the monitor. This will give you the necessary slack you need to do your dirty work. BTW, we're not disconnecting the ribbon cable from its connections- that would be bad - just remove that haphazardly placed piece of tape used to keep the thing snug and save it for when you're ready to close it back up. OKAY! There a four tiny screws that affix the green circuit board. You'll need a thin, jewelers type phillips head or a one from a synthe-sized tool set to remove these. Now, if your issue is like mine, you'll see when you again carefully remove the circuit board, that the on/off button has cracked off of the piece that holds it. This is why the button remained stuck in one positon when it was depressed. Re-align it so that it is uniform to the other buttons and place a few small strips of cut electrical tape to hold it in place to the end where it broke off. Crazy glue or the like won't give the button the flexability it needs and will probably just crack again. What the tape (I layered 3 strips) will do, once the circuit board is scewed back, is allow the button to return to position after it's pushed. I just did this and so far, after a dozen on/offs it's still working. Good luck. Go have a beer.
Dell Dimension... | Answered on Sep 11, 2017
You need to reset it to factory defaults. Several youtube videos can help you (I have exact printer but book is put away). Have you done anything to it lately with ink cartridges and the like? may need to get some mineral spirits, take out ink cartridges, and clean contacts with swab. Try the reset first, though.
Dell Dimension... | Answered on Aug 03, 2017
it can be one of 2 things:
1. if the battery charge light is all that comes on then you motherborad is busted.
2. if the power light turns on without the screen showing anything then you will need to replace the screen, but first connect it to an ordinary PC monitory and see if it works from there before changing anything.
Dell Dimension... | Answered on Dec 27, 2016
You should call on 1-800-585-2494 Toll Free at Customer Care and get help for Dell.
Dell Dimension... | Answered on Dec 21, 2016
Your computer will need some upgrades. This dell has a max memory of 2 gigabytes. The memory type is pc2700. You need to install a PCI video card. Newegg.com has a decent one for about 40 bucks. 2 gigabytes of memory should cost about 70 bucks. If the dell doesnt have a DVD drive you will have to get one too. <less than 30 bucks> Then and only then will this computer be able to play games or play videos.
Dell Dimension... | Answered on Oct 26, 2016
If your trying to cancel your order, it depends on where the computer is in their system (not yet built or not yet chipped). Click on this link and then on the "can I cancel my order" link. Then follow the instructions. http://www.dell.com/support/Contents/us/en/19/article/eSupport-Order-Support/order-change-returns
Dell Dimension... | Answered on Aug 13, 2016
follow these easy steps:
1)open my computer
2)click on Add and Remove Programs ,wait till is loaded then select your program that you want to uninstal and click Remove.
Dell Dimension... | Answered on Jul 08, 2016
how much space do you have? you should only delete things like pictures, documents or from the downloaded folder you no longer want otherwise uninstall programs you no longer need DoNOT delete them
Dell Dimension... | Answered on Mar 24, 2016
Dell Dimension 2400 PC Desktop Logo
2,193 questions posted
Ekse
Alun Cox
Thomas F. Schneider
View Most Popular
Dimension Dell
  • Dimension Dell
Most Popular Question
need line owners manual dell dimension
  • Computers & Internet
