20 Most Recent
Belling XOU270 / XOU271 Electric Single Oven Questions & Answers
No heat from oven although fan and light are both
hello gavin..... Usually, when an oven won't bake, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
This is an inexpensive part and relatively easy to replace. Call your local appliance store to obtain the part and the instructions on how to install it. Joe
Thanks for choosing Fixya!
The oven stopped working so I replaced the oven
Re:The oven stopped working so I replaced the oven element (ES101150)
successfully. Now a year later the grill has stopped working so I
replaced the grill element (ES548158).
The first success had been a lucky dip. before replacing an element you have to read Ohms at element, if reads infinity (open) replace it, if not, read volts coming from timer board.
Re:Now the fan, the oven, the light and the grill all don\'t work but the timer still works. Is there an internal fuse somewhere ?
There is no fuse. Depending on the country of use, the power cord may be fused, but if the timer is working, that is not the problem.
The grill element should be a double element in this model. Grab the old grill element and read Ohms, to find out if the old one was open. If one of the elements was open, then the element was bad. If it was not , then there was a different problem causing no heat. The circuit comes from timer board, passes through temperature sensor and powers fan and element. The job is done reading Ohms to find out if there is an open in wiring to grill, and if there is none, reading Volts at OEC (oven timer) contacts to find out if timer is working (timer is expensive).
Parts for this oven are scarcely available from third party, better ordering from manufacturer through the number listed on the owners manual.
WHY CANT I TAKE ELEMENT OUT
If you cannot remove screws from inside oven compartment, then, yes, it will be neccescery for you to remove the oven from it's housing to gain access to the screws from the rear.
My hob is working but there was a bang in the oven
If it is a fan assisted oven, and the fan is working o/k, then I would suggest that you fit a new oven element, if the fan is not working, then you are going to have to investigate further.
Please rate my solution.
Thanks.
Oven will not heat past 100 degrees
More of a clarification request:
Is the oven remaining on all the time(oven light stays on)and the temp not going above 100 ,or is it going to 100 then switching off?
Replace Bottom Element in Belling XOU270
If this is a fan assisted oven, then there is no bottom element, only the fan element..
Remove the panel at the rear of the oven, there you will see the element, remove any screws that you can see and pull element towards you, disconnect the leads, don't loose them, and replace element.
If no screwws are visible then you will have to remove the oven from housing and do it all from the rear of the oven. Make sure power is off before you do anything.
Good luck.
Plz rate my solution.
Thanks.
