20 Most Recent
Dell Inkjet 720 Printer Questions & Answers
Dell Color Printer 725 - Communication Not Available
I have seen that in most of the cases (with lexmark and dell printers)
it is fixed by reinstalling the printer software. Be sure that you
completely remove the older drivers using the cd or using add/remove
programs.
Dell photo printer 720
NO u just need first to UNISTALL driver then restart pc and install again from device menager not from setup
Dell 720 printer won't print
Our Dell AIO A940 stopped printing black ink. Tried so many things, and finally (a year later) got it to print by selecting:
PRINT, PROPERTIES, PAPER SETUP, SPECIALTY PAPER, PHOTO/GLOSSY
It's worth a try! Good luck!
Dell 720 Printer failure
it may not really be the lever it may just need some lube. if you use some vasline and rub it on the bar and then move the printer head up and down put more vasline until the head moves slwly then try printing this may work.
Dell 720 printer not spooling
printers download the data in bursts from a memory stored in the computer
this spooling of tasks allows a single printer to print the next job and not mix up jobs as they are entered for printing
for this to work you have to install the driver for the printer into the computer and set printer priorities from other print sources
Printer problem
on photos, If you have a laser printer with half a meg of RAM and you try and print a full page graphic at 300dpi you only get half a page because the printer runs out of RAM.
You can get a full page by printing at 150dpi.
could also be that the encoder strip has become fogged with aerosol, and needs gentle cleaning.
Good luck
Dell 703w will not print
There are two things that might be the problem. The print head is dirty or thenew ink cartridges are not the same brand/type of ink you used before.
If the print head is dirty some of the ink doesn;t get spray ed out so the colour and sharpness are off. This is typical of any inkjet and usually occurs if you don't print all the time. What happens is you print something and then come back a week later and it won't print properly. the ink from the previous print job has dried and covers some of the print head. The printer does a clean cycle when you start but this doesn't mean it really cleans everything off. If this sounds like what has happned the fix is to run multile cleaning cycles. It can take anywhere from 10 to over 30 clean cycles before it starts to print properlly, If it is not too bad then 4-10 cleans and you are printing.
Sometime you put a new caertifge in and the inks don't like each other. They actually form a gell.The fix for this is of course more clean cycles until the bad ink is out of the print head.
If you look at start then printers then click on the printer installed to open and then look for a cleaner or clean cycle button and click to start. You will use both iink and paper but this is what you need to do (a few times) to male it behave.
