20 Most Recent
Dell 540 Photo Thermal Printer Questions & Answers
Only prints top half of picture...
Throw it away the Thermal heater has failed and it will cost more than the printer to fix. Dell will not support this item so lie the rest of us you are stuck with a Lemon. Yes Dell sucks, yes they **** again and yes they will keep sucking!
My Dell 540 printer only prints 1/2 (upper) of the photo
Do you have any other devices installed on the machine that are also
parallel (hard drive, CD/DVD drive, etc.)? This may cause this
reaction.
Is this a laser printer? The drum may not be holding a charge.
Are you sure the driver installed is the correct driver? That may be the issue as well.
Dell 540 photo printer
It might be time to, but try these first:
(1) Try rebooting the computer (Press
Ctrl+Alt+Del>Shutdown>Shutdown OR press and hold the power button
down on the front of the workstation/computer/tower/CPU until the unit
turns OFF)
(2) If that doesn’t work, then try clearing the print queue:
Start>Settings>Printers>Double-click on the
printer>Right-click on the print job(s) and click
cancel/delete/purge documents and try reprinting a document
(3) If that doesn’t work, then try a power cycle: Try turning the
printer off, then unplug the power supply from the printer, then unplug
the USB cable from the printer then the back of the computer; wait 30
second; then plug the USB cable back into the computer, then back into
the printer then plug the power supply back into the printer and turn
it on – run a test print
(4) Run a Test Print: Start>Settings>Printers>Right-click on the printer>Properties>Print Test Page
Dell 540
Try cleaning the rubber wheel that picks up the paper. There may be paper dust on it. Use alcohol on a clean rag. and wipe it clean.
Looks like to heaters are going How long have you had it Still under warranty?
If so send it back or ask for a replacement.
