20 Most Recent
Dell A960 All-In-One InkJet Printer Questions & Answers
Dell A960 All-in-one printer and Windows 7
1st You download Printer Driver.
Dell Printer Driver For Windows 7
After this install the Printer driver in the system.
Installation of Printer Driver
- Go to the control panel
- Click on the System Icon
- Click on the Hardware Tab
- Click on the Device Manager then
- Select the Unknown Device or printer device where yellow Question Marks sign on it.
- Right click on it and uninstall it.
- After this go to the top of the device manager and click on scan for hardware changes.
- Driver installation Wizard start.
- Brows Your Driver from the Hard Disk and click on next.
- Driver will be install.
11/5/2019 7:20:14 AM •
Dell A960...
Answered
on Nov 05, 2019
Job Status Window Interface has stopped working.
The issue usually occurs if you are using windows xp drivers on a vista machine. It's strange that the error does not come up when printing from internet explorer 7.0.
There is a file on support.dell.com that you can run to remove any xp drivers and then run the vista installation file. that should take care of these error messages from the operating system.
you can copy and paste the following links to download and run the files :
Patch file to remove xp drivers:
http://support.dell.com/support/topics/global.aspx/support/downloads/en/downloads_splash?c=us&l=en&s=gen&~mode=popup&file=224499
Driver for vista
http://support.dell.com/support/topics/global.aspx/support/downloads/en/downloads_splash?c=us&l=en&s=gen&~mode=popup&file=203951
11/10/2018 6:57:33 AM •
Dell A960...
Answered
on Nov 10, 2018
Scanner locked
Try unplugging for a little while to reset. Also see if there is a power button. Press and hold
10/18/2013 7:35:28 PM •
Dell A960...
Answered
on Oct 18, 2013
My dell A960 printer has hardware error 0502.How
Error 0502 and 0504
Hi there
On the multi function machine seems to be a coating on the metal rod that the cartridges travel on. Just wipe this rod with a Kleenex and the problem seems to go away.
Somehow it presents a drag on the cartridges and causes an error.
Myself I would put a little bit of oil after on a cloth and wipe along the bar.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
10/29/2012 8:38:14 PM •
Dell A960...
Answered
on Oct 29, 2012
Cartride error 50c on display
Hi there Error 50c
ok ok try see if this works
Regarding the Dell A940 "Error 50c"....the user guide doesn't seem to mention "Error 50c". They do, however, mention a "Cartridge Error" on page 52 of the manual. They claim this means that the printer has detected a short circuit (fuse/resister) in the cartridge. As you may or may not have noticed in the manual, this is what they recommend doing about it:
1) Press Power to turn the printer off.
2) Lift the printer cover/lid (scanner unit) until the scanner support holds it open.
3) Turn the printer on.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
4) Remove the color ink cartridge.
5) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the black cartridge with a new black cartridge.
If the error message does not display, repeat steps 1–3 and then go to step 6.
6) Reinstall the color cartridge and remove the black ink cartridge.
7) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the color cartridge with a new
color cartridge.
If there is no error message (indicated by flashing lights), repeat steps 1–3 and then reinstall both ink cartridges.
8) Lower the printer (scanner unit) until it is completely closed.
If you get the error message again, while both cartridges are installed, replace both of the cartridges.
Basically, what they want you to determine is,....if the short circuit is with the "black ink" cartridge or the "color ink" cartridge and then replace the cartridge that has the problem.
You may have to buy a new cartrige.
10/28/2012 4:40:50 PM •
Dell A960...
Answered
on Oct 28, 2012
I Don't Have The Key
Darryl - lift up the top part of the scanner body (the silver part should separate from the black base) and let the kick-stand support the top part. Then look underneath the top part; there'll be a green tab sticking down from the top. If you look closely, you'll see little icons next to it that look like padlocks, one in an unlocked position and one in a locked position. Push the green tab away from you so that it lines up with the unlocked padlock, and that should do the trick.
7/23/2012 10:09:35 PM •
Dell A960...
Answered
on Jul 23, 2012
Hardware error 0502. I cleaned the steel bar with
Hi there
Can only try this
5/4/2012 11:54:17 AM •
Dell A960...
Answered
on May 04, 2012
User ManualDellPrinter&faxfor a a960
Hi Susan,Please note that your printer
cannot receive soft copy faxes,it
can only send them.Click
here for the manual downloads in pdf format.Hope this helps.Thanks!
11/8/2011 9:08:14 AM •
Dell A960...
Answered
on Nov 08, 2011
