20 Most Recent Dell A920 InkJet Printer Questions & Answers
12answers
Dell A920 with Windows Vista
Believe it or not... the driver is buried on the Dell site for Vista 64-bit. I search and searched ... and there it was.
http://support.us.dell.com/support/downloads/download.aspx?c=us&l=en&s=gen&releaseid=R153048&formatcnt=1&libid=0&fileid=203948
In any case, I downloaded it, installed it, and it works fine. All the buttons (scan/copy) on the top work as well as printing. Now if I could just get my old XP machines to print to it on the network. But.. I think that is another thread.
12/2/2021 7:24:05 PM • Dell A920 InkJet... • Answered on Dec 02, 2021
2answers
Copier/scanner not working
have u installed all the software from the cd? here is the manual http://support.euro.dell.com/support/edocs/systems/a920/en/index.htm
10/1/2018 6:04:43 AM • Dell A920 InkJet... • Answered on Oct 01, 2018
3answers
I connected my laptop with
You have to install the printer drivers. Click here to download the driver for DELL A920. Select the driver file according to your Operating System (e.g. Windows XP). After downloading the file, just double click it and follow the on-screen instruction. This will install the printer and you would be able to print.
Good Luck!
Hope this helps!
CreativeTECH
4/24/2017 5:41:43 AM • Dell A920 InkJet... • Answered on Apr 24, 2017
2answers
I have a Dell A920 printer that will is connected
Dial Dell Printer Tech Support Phone Number1877-778-8@9@6@9for online support. For further Info Click:https://goo.gl/RlPU1p
4/20/2017 10:24:25 AM • Dell A920 InkJet... • Answered on Apr 20, 2017
2answers
I want to download the HP DESKJET F380 DRIVER FOR WINDOWS VISTA
Here is the driver download page
Software & Driver downloads HP Deskjet F380 All-in-One Printer
A web page will open, select country, operative system etc., and click on download now loaction.
Chose to download the file in my documents when asked.
After downloading,find the file, double click on the file, if you get in troubles ,thenfollow instructions below to reset and reinstall:
  • Unplug printer USB.
  • Go to control panel >> installed printers in Windows and remove (delete ) any installed printer from printer list.
  • Download driver from website and run the file.
  • Follow driver installation wizard.
  • Plug back printer when prompted from installation wizard.
Do not forget to rate the solution appropriately.
7/29/2016 12:48:32 AM • Dell A920 InkJet... • Answered on Jul 29, 2016
2answers
I have a dell printer
First run Delete Print Jobs to remove any stuck print jobs in the queue.
Disconnect the printer.
Download and run the patch(printer cleanup utility) until it prompts you to restart your computer.
Restart your computer. Make sure the printer is removed. Manual Printer Driver Removal
Download and install the Vista 32-bit drivers for Windows 7 32-bit or the Vista 64-bit drivers for Windows 7 64-bit. Install the Vista drivers in the Vista Compatibility mode You'll get a message, the printer is not connected. Connect the printer at this time(powered on)
Links to the patch/drivers can be found at...
Dell A920 All-In-One Inkjet Printer owners thread (W7)
Virus programs and firewalls will block communications.
Rick
5/22/2015 8:22:48 PM • Dell A920 InkJet... • Answered on May 22, 2015
2answers
Is there a windows 7 driver for the A920
First run Delete Print Jobs to remove any stuck print job in the queue.Disconnect the printer.Download and run the patch(printer cleanup utility) until it prompts you to restart your computer.Restart your computer. Make sure the printer is removed. Manual Printer Driver RemovalDownload the Vista 32-bit drivers for Windows 7 32-bit or the Vista 64-bit drivers for Windows 7 64-bit. Install the Vista drivers in the Vista Compatibility mode You'll get a message, the printer is not connected. Connect the printer at this time(powered on).Links to the patch/drivers can be found at... Dell A920 All-In-One Inkjet Printer owners thread (W7) Remember virus programs and firewalls will block communications.Rick
5/22/2015 8:21:46 PM • Dell A920 InkJet... • Answered on May 22, 2015
2answers
My printer won't work. I want to know which USB
Any USB port should work. There is no "printer" USB port. The "U" stands for "Universal" to signify that any peripheral equipment will work.
Can you explain the problem a little further and perhaps I can give you an idea of how to proceed?
Thanks for using Fixya...awaiting your reply.
Wayne
1/5/2015 9:44:55 PM • Dell A920 InkJet... • Answered on Jan 05, 2015
I am not getting incoming calls,but i can callout
It may be your phone carrier's issue. Have them test the line.
11/23/2014 11:18:00 PM • Dell A920 InkJet... • Answered on Nov 23, 2014
0answers
My Dell A920 Inkjet Printer will not recognize my
Is it a Dell cartridge or a generic cartridge? No-name cartridges sometimes lack the chip which the printer looks for. Return the cartridge for an exchange.
8/29/2013 12:41:45 AM • Dell A920 InkJet... • Answered on Aug 29, 2013
Printer not switching on
unplug printer for a minute and plug it back in,this might reset it?if that doesn't work if theres an red X on the panel,hit that and maybe it will clear it?good luck:)
7/10/2012 1:47:22 AM • Dell A920 InkJet... • Answered on Jul 10, 2012
My Dell A920 prints blank paper.
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.It may be more cost effective to buy a later model and better printer thanreplace the print head.
3/1/2012 9:47:27 AM • Dell A920 InkJet... • Answered on Mar 01, 2012
7answers
Flashing Green Light/ Computer can't communicate with printer......
Hi. The flashing code signifies that there is a fault with the connection between the ink cartridge and the printer - usually because either the tape is still on the cartridge or maybe some glue from the tape still on the contacts. In my case, I think the cartridge was simply knackered, so I threw it away and opened yet another ink cartridge. It now works fine.
If you want to test yours, simply take out both ink cartridges, and re-insert them one at a time. If you've put a working cartridge in the flashing will stop; if you've put the dodgy one in it'll still flash. Just replace the dodgy one.
Hope this helps.
1/14/2012 1:27:53 AM • Dell A920 InkJet... • Answered on Jan 14, 2012
Printer not working
Hello Cindy,Does the printer power on?What happens when you try to print?Check the printer connections to the PC.Unplug it completely from power and from the PC.Reboot your PC.Connect everything again.Check through the paper paths for any obstructions.Check the printer settings on your PC and make sure its set as the default printer.Clear any print queues.Try printing now.Know your printer from the link below.search.dell.com/results.aspx?c=us&l=en&s=dhs&cat=sup&cs=19&k=Dell+A920&rpp=12&p=1&subcat=dsn&rf=all&nk=f&sort=K&ira=False&~srd=False&ipsys=False&advsrch=False&~ck=anavHope this helps.Thanks!Kenneth.
1/9/2012 5:39:26 PM • Dell A920 InkJet... • Answered on Jan 09, 2012
Dell A920 InkJet Printer Logo
Popular Tags
296 questions posted
Top Dell Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Ngoro
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Dell Office Equipment & Supplies
Most Popular Question
dell a920 windows vista
  • Office Equipment & Supplies
