20 Most Recent
Dell (8H390) Sound Card Questions & Answers
No sound in speakers or headphones
Have you tried all of the following:1. Try playing sound from more than one program2. Make sure your computer is not muted (look for the speaker icon in the taskbar)3. Restart the computer
No sound on pc,,ran diagnostics
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
if you dont have a motherboard disc you will have to download the drivers
click start control panel administrive tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
hope this helps
Solution audio in my xp
if you are having problems
with your sound
game controllers you might see a yellow question mark? Right click to reinstall
drivers or uninstall
settings there
also
icon in taskbar
problem
have you tried this control panel sounds and
connection is good
make sure you have an earth
******** before touching any parts inside your computer
hope this helps
I am using a Dell optiplex 320 here i use
This is called and Echo, if you can get Realtek drivers or if already installed you will need to configure them not to produce this echo or at least minimize it. Click on the Speaker icon on the lower right hand of your monitor this will allow you to configure your Realtek HD Audio software.
Click on sound manager ......on the Menu's click on the Microphone and select Noise Suppression this will do the magic.
No sound. My system crashed and I've had to
hi steve
You need to go to the dell website and download the latest drivers for the sound first.
after you install those drivers, go to device manager and check if there is any Audio and sound option there or not.
No sound card detected
you might have to uninstall then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have made the correct adjustments there
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can make adjustments there you can also tick in the box place icon in taskbar
hope this helps
My skype is telling me i needs to access my sound
click start control panel administrive tools computer management device manager any yellow? ! question marks or red x will tell you that you need to reinstall the driver/s for this device
to do this right click on the ? x ! select reinstall driver
the drivers might have been corrupted by something or you might have got a virus run your antivrus program
as for the sound
control panel sounds and audio,volume you can adjust the volume or advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers also
control panel,administrive tools,computer management,device manager scroll to sound,video and game cotrollers could be a yellow question mark? right click to re-install drivers
hope this helps
My computer says it has
Here is a guide to the sounds on a computer
the drivers might have been corrupted by something foreign or you might have got a virus run your antivrus program
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it
hope this helps
Well my sound
Hello, if your sound card says "Null" it means that your computer isn't seeing the drivers for the card. Here's what to do. First, find the exact model of your Dell. Write this down. Now go to dells site and look for "Sound" drivers. http://support.dell.com/support/downloads/index.aspx?c=us&l=en&s=gen Download the driver and run it. This should install the newest drivers for your sound card. Turn off the computer and re start it. That should be it. If this doesn't work your sound card may be bad. Hope this helps.
It says no soud device
the drivers might have been corrupted by something or you might have got a virus run your antivrus program and test for a virus then
you might have to uninstall then reinstall either the sound drivers or the sound card make sure you have both of these devices baked up to a disc before uninstalling
a yellow? question mark means you need to install/update driver right click to install driver
as for the sound
audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager scroll to sound,video and game cotrollers could be a yellow question mark? right click to re-install drivers
hope this helps
No sound. No error code.
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure that you have selected the right speakers or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
hope this helps
Soundcard problems
Try re-installing the audio driver.
Normal
0
You can download the drivers from Dell WEB site, the
support download page. Make sure you select your model desktop or laptop,
better still, type in the Service Tag number, it is printed on the label on the
bottom of the laptop and on the back or sides of a desktop. (If the Service Tag
label is missing then go into the BIOS setting and on one of the BIOS pages,
the Service Tag number will be displayed). This will open the page where the
specific drivers for your model computer are located. Also make sure you select
the Windows XP or Vista version of the drivers for your Windows operating
system. Click on this link to download the drivers: -
I recently deleted my c
You can download the drivers from Dell WEB site, the support download page. Make sure you select your model desktop or laptop, better still, type in the Service Tag number, it is printed on the label on the bottom of the laptop and on the back or sides of a desktop. (If the Service Tag label is missing then go into the BIOS setting and on one of the BIOS pages, the Service Tag number will be displayed). This will open the page where the specific drivers for your model computer are located. Also make sure you select the Windows XP or Vista version of the drivers for your Windows operating system. Click on this link to download the drivers: -
Dell Studio 17 windows 7/ Sound disappeared completely.
The best thing to do would be a system restore. You might have installed some software or changed some settings which made the sound disappear.
Click on Start>All Programs>Accessories>System Tools>System Restore and follow the on screen instructions.
Sound resembles under water at times. Do i need a
Could be that all you need to do is update your audio device driver. Go to the Dell web site, follow links for support and downloads, you'll have to enter the details of your device and operating system as you go.
No sound got eroor code 1b63:061b , 0f1b ,
This error code is usually generated by a Dell Computer. I suggest that you perform an extended test by pressing the F12 Key at the startup of the Computer.
Furthermore, you may go to the Device Manager and check the status of the audio devices which are listed under the "sound, video, and game controllers" category.
I suggest that you try uninstalling and reinstalling the Audio devices from the device manager.
In order to uninstall the audio devices from the Device Manager, please right click on the device and then click Uninstall. It's required to restart the Computer after uninstalling a device. Once the Computer is restarted, reinstall the appropriate Audio driver. You can download the audio driver from the support site of your Computer manufacturer.
