20 Most Recent Dell 0Y3740 Keyboard Questions & Answers
3answers
Some keys of my laptop are not working?
Some keys on my fujitsu lifebook stopped working so temporarily solved problem by plugging in a desktop keyboard to the usb port.
11/7/2021 11:31:34 AM • Dell 0Y3740... • Answered on Nov 07, 2021
KEYS 9OL. NOT WORKING SOMETIMES
I get the same thing, until I press the shift key, then it comes back.... for a while. Very odd. So-far only witnessed this under Linux Mint and Ubuntu, just resetting the laptop back to Windows to see if that helps...
8/25/2021 11:57:10 AM • Dell 0Y3740... • Answered on Aug 25, 2021
Skipping keys on dell 1545
that laptop was one of the worse ones they built. the ram was bad, the hard drives go and the keybord does not last long. even the batery seems to go bad quick. then the worse part was it was all because of windows VISA. if you do go back to xp and then laod everything and the keyboard still give you problems you might wnat to replace it.
9/17/2018 1:22:11 AM • Dell 0Y3740... • Answered on Sep 17, 2018
I want to remap the number pad where the 1,2,3 numbers are across the top and 7,8,9 are across the bottom. How do I do this?
A Google search netted this free key mapper: https://lifehacker.com/5883003/the-best-key-remapper-for-windows
1/8/2018 2:55:39 PM • Dell 0Y3740... • Answered on Jan 08, 2018
My computer misses letters and spaces when I type
Does it only do it when you are on line? If so it could be that your browser is low on resources due to pop ups, ads, etc. Google ad block for your specific browser to block out the garbage and free up your browser. Does wonders.
9/21/2017 9:36:28 PM • Dell 0Y3740... • Answered on Sep 21, 2017
Where do I get replacement feet for a dell
Its not worth getting the replacement feet, you can purchase a new keyboard from cyberguys.com
4/16/2017 4:30:15 AM • Dell 0Y3740... • Answered on Apr 16, 2017
3answers
Can't type double letters can't backspace more
Push the shift key down until it beeps and it should unlock the keyboard and allow you to type normally.
3/27/2016 7:47:46 AM • Dell 0Y3740... • Answered on Mar 27, 2016
2answers
My daughters key board on
First, try to connect an external USB keyboard & see if it will work fine.
If the external USB keyboard works fine, then you will need to replace your laptop's keyboard, as there is almost nothing that can be done to fix a defective laptop keyboard.
3/27/2016 7:46:25 AM • Dell 0Y3740... • Answered on Mar 27, 2016
How do I find numerical lock button on Dell windows 8 keyboard?
On the Dell 0Y3740 for the Dell Inspiron 500M or Latitude D800, the Num Lock (Lock replaced by a symbol) key is on the top row of keys. It's a short row and the Num Lock is the third key from the left (or the fifth key from the right). In blue, the key has Scroll and the lock symbol. On a slightly different model, the key may be in a different spot. However, it will probably have a similar placement near the Print Screen and Pause/Break keys. (Usually these keys will be near the function keys or just above them for a keyboard without a separate 10-key area.) I hope this helps. Cindy Wells
8/21/2014 11:52:53 PM • Dell 0Y3740... • Answered on Aug 21, 2014
How to remove keys from mk700 keyboard
Are you wanting to clean it? You can use a butter knife or a flat screw driver .to gently pry the keys off. Doe this while pc is off.. Take the knife and place it between the keys and gently lever down at and angle. The key will be a little resistant but will pop off. Sometimes a keyboard has a few keys such as the space bar the are held with little metal bar which can be annoying when placing the keys back in. When placing them back in you will hear a little snap. This just means it is in. No worries.
8/21/2014 11:45:50 PM • Dell 0Y3740... • Answered on Aug 21, 2014
How do I get an underscore on the dell computer
Hold the shift key and press the - key
7/29/2014 9:23:26 AM • Dell 0Y3740... • Answered on Jul 29, 2014
How to remove keys from mk700 keyboard?
This works for most keyboards: Take something sturdy and hard but not sharp, such as a butter knife. Insert it under the front of the key just a little way, don't force it. Pull upwards gently. The key should pop off. You can clean them with gentle dish soap and wait until they completely dry, then put them back on. If the key is still sticky, take it off again and use a cotton swap dipped in alcohol (not dripping--rub against the inside of the bottle so it's just moist) and gently swab the area underneath the key. I have cleaned numerous keyboards because I have kids who share my desk tops and kids are frequently sticky. :)
7/13/2014 8:49:31 AM • Dell 0Y3740... • Answered on Jul 13, 2014
The keyboard on my dell laptop has stopped working
You can hook up a usb mouse or keyboard, then try removing the keyboard from the device manager and restarting the computer. If that doesn't work then the keyboard has probably gone bad and you'll have to swap it out with a new one. They usually pretty cheap via ebay.
7/8/2014 2:48:15 PM • Dell 0Y3740... • Answered on Jul 08, 2014
2answers
Should i turn my laptop off when i am not using
Yes you should, to save battery/electricity and to prolong it's life.
6/17/2014 8:29:37 PM • Dell 0Y3740... • Answered on Jun 17, 2014
Hello.Please, WHERE is the backspace key?????
usually it is 2 up from the enter key sometimes simply labeled BACK
3/23/2014 11:46:51 AM • Dell 0Y3740... • Answered on Mar 23, 2014
I just bought dell inspiron
just open on screen keyboard and dail shift+(<,.>) symbols
3/9/2014 7:57:55 AM • Dell 0Y3740... • Answered on Mar 09, 2014
I'm trying to put an fada (Irish language accent,
Hi does anyone know how to get fadas on a Toshiba laptop(windows 8) If you do please tell me!!!
2/20/2014 6:34:12 PM • Dell 0Y3740... • Answered on Feb 20, 2014
Dell 0Y3740 Keyboard Logo
530 questions posted
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
View Most Popular
  • Dell Computers & Internet
Most Popular Question
dell inspiron n5010
  • Computers & Internet
