Dell Axim Computers & Internet • Uploaded on Sep 09, 2013
Hi
All WM devices has OS stored in ROM, when you need to restore it to original state, you can hard reset the device. You do not get a copy of OS on the cd. It's not that easy to wipe out the ROM, if that happened more than likely it is a serious hardware problem. And as you already found out, you can download OS ROM upgrade from Dell. It will come with utility to flash device's ROM. The upgrade contains all of OS files. The latest version for your x30 is A06:-
http://support.dell.com/support/downloads/download.aspx?c=us&l=en&s=gen&releaseid=R101483&SystemID=PDA_AXIM_X30&servicetag=&os=PPCA&osl=en&deviceid=6672&devlib=0&typecnt=0&vercnt=3&catid=-1&impid=-1&formatcnt=1&libid=7&fileid=131500 Download and install the utility
http://supportapj.dell.com/support/downloads/driverslist.aspx?c=in&l=en&s=gen&catid=13&dateid=-1&formatid=-1&hidlang=en&hidos=PPCA&impid=-1&os=PPCA&osl=EN&scanConsent=False&scanSupported=True&servicetag=1ZB3X41&SystemID=PDA_AXIM_X30&TabIndex=&typeid=-1 Follow the steps below: Plug the AC adapter directly into the Axim and check the power LED located in the power button.toggle power on the Axim, perform the following steps: Press the power button to turn the Axim off. Press the power button again to turn the Axim back on.Inspect the connector on the Axim for any bent or broken pins.Inspect the connector on the sync cable or cradle for any bent or broken pins. Inspect the cable itself for any nicks, tears, or other damageTurn on the Axim. Use the stylus to press the reset button until it clicks. See Figure 1, Figure 2, or Figure 3 for the location of the reset button on the Axim models. Disable Or Remove All Firewall Applications On the Computer Uninstall ActiveSync Click Start, point to Settings, and then click Control Panel.Double-click Add / Remove Programs. Locate Microsoft ActiveSync in the program list. Click Remove,Reboot the system. Install ActiveSyncInsert the Axim Installation CD into the CD or DVD drive. Follow the prompts to install Microsoft ActiveSync. Now reseat the Axim, perform the following steps: Remove the handheld from the cradle or sync cable.Put the handheld back in the cradle or reattach the handheld to the sync cable.Attach the AC adapter to the handheld or the cradle.Turn on the handheld by pressing the power button,now Verify That the Axim Is Seen In Device Manager.Remove the Axim from the cradle or sync cable.Double-click the ActiveSync icon on the Windows toolbar to load ActiveSync.Click File and then click Mobile Device. Click to highlight the partnership you want to delete.Click File and then click Delete Partnership.Click the Yes button.
However go into the device manager in windows and remove the usb universal host controller entries under the usb controller. And then shut down the system wait for 2 mins and then turn on the system. Please make sure no usb device is connected to the system it will reinstall the driver automatically and then you can connect the axim.Please get back to us if you have further query else please accept the suggestion.Thank you for contacting fixya.com
104 questions posted
191 Questions
122 Questions
68 Questions
47 Questions
44 Questions
