20 Most Recent
Compex (RE100ATX/WOL) Network Adapter Questions & Answers
My devise compex after i feed a program it would reply error contact with the agent.
what is a devise. (device?)
you posted to computers, and never told what PC it is firsts
Compex means what, COMPAQ (HP ) PCs'?????????
tell what PC it is first
then tell what fails. what are you doing exactly at the time of failure
even post screens with errors as PHOTO below
good luck to you;...
compex is medical device , THAT:? IDK what you have in hand.
Power adaptor got burned
Use Google the Internet for a power adapter for your model hub.The old power adapter will have a label which states the voltage and amp this unit delivers.
Dear Team,
we had configured the
your network speed provided by your ISP is divided in certain amount of hardware or PC
when you used much more PC then your network will probably goes down.
I suggest you to contact your ISP ( Internet Service Provider) and upgrade your network status and speed, depend in the amount of your computers.
I am in India and have a MAcbook. I am trying to
Router is independent of the Operating System installed in the Computer. You have to configure the router according to your ISP (in this case BSNL). You can refer the User Guide of the Router for the instruction to configure the Router.
Or provide the model # of the Router so that I can give you the instruction to configure the Router.
Good Luck!!!!!!!!!!!!!!!!!!!!!!!!
How to turn off the router's firewall
1. Insert the Product CD into your CD-ROM drive. The CD will run automatically.
From the Utilities section, select to install the uConfig utility to your hard disk.
2. When the utility has been installed, double-click on the uConfig icon. The
following screen will appear, click on the Yes button to proceed.
3. Select the router from the products list and click on the Open Web button. To
retrieve and display the latest device(s) in the list, click on the Refresh button.
4. Do not exit the uConfig program while accessing to the web-based interface.
This will disconnect you from the device. Click on the OK button to proceed.
5. At the login page, press the LOGIN! button to enter the configuration page. The
default password is “password”.
6. For the first time login, you will be prompted to select your time zone setting first
before accessing the router’s main web page. Take note that during the next
and subsequent logins, you will not see the System Time Setting page again.
7. You will then reach the web page of your router’s web-based interface.
8. Under the SECURITY CONFIGURATION command menu, click on Firewall
Configuration.
Como cancelar el winter driver
EnglishIt is a car, and cars are complexbut no car was told , maker, model , and year.we can not guess cars. post the VIN? and all that is knownname a problem what can't your car do right?name symptoms or evidence that is confusing to you.then answers can happen.onlygood luck , finding itand Mucho Gusto.my guess now is this is posted to computer forumand not to CARS !must be some odd traction controls thing'but 10,000 models of cars,
I need a product key
Have you actually purchased Visio, or are you just trying to get it for free?
As a software guy, I would have to advise against piracy. :)
There are several ways to get Visio for cheap. If you are a student, there are discounted versions available online and in stores. Also, you can check with your school for even cheaper options sometimes. Try the university bookstore if available. Or a Computer Science department maybe.
If you are working, and your company uses MS Office applications, find out if they have the "Microsoft at Home" program. You can get MS Office applications for really cheap that way. I can get Visio through my company's "Microsoft at Home" program for a few dollars.
My Employer Says They Are Going To Cut My Wages. Can They?
If you are in the middle of a contract, then cutting your wages is almost certainly a violation of your employment law rights. While I am by no means an expert on this matter, I did have a similar issue years ago - mid-contract wage cuts - and I hired an
employment attorney to fight the case on my behalf. It turned out that my employer was basically looking to scare people into taking the wage cut.
They got into some pretty serious legal trouble for their transgression, and nothing happened to me in terms of wage cuts after that. If you are between contracts, your employer can re-negotiate your salary, but as far as I am aware, if you are in an agreed-upon contract, they cannot just decide to reduce your salary. If you want to settle matters, contest this action with support from a legal professional.
