20 Most Recent
Compaq Athlon XP 2000+ , 1.67 GHz Processor Upgrade Questions & Answers
Processor
hi,
from your reference i could get the info that your pc is running with the mainboard similar to FIC - am37,and with that the below mentioned processors are supported.
Recommended Speeds:
AMD Athlon? XP 2600+ (266 FSB)
AMD Athlon? XP 2400+ (266 FSB) Model 10 w/ 256K Cache
AMD Athlon? XP 2200+ (266 FSB) Model 10 w/ 256K Cache
AMD Athlon? XP 2100+ (266 FSB) Model 8
AMD Athlon? XP 2100+ (266 FSB) Model 6
AMD Athlon? XP 2000+ (266 FSB) Model 8
AMD Athlon? XP 2000+ (266 FSB) Model 6
AMD Athlon? XP 2000+ (266 FSB) Model 10 w/ 256K Cache
all the best..
sreejith
Out of frequency range set lower resolution
reboot the system by pressing F8 if your using windows OS and select last good configuration.
you can try also selecting Enable VGA mode (press F8 while rebooting and select ENABLE VGA mode).
hope this helps, please rate.
I want to install xp on compaq nx 6310 give the procedure with pendrive
2006 PC (HP.coM) 16 years old.. ouch.
XP (microsoft) is now a horrible virus magnet, and there is ZERO support now, are you using the last XP earth 2020???
gee google that. 2001 to 2007 was XP rein , vista 2007
I bet there are 1millons of web site still with XP usage .(old topics)
google them. but Microsoft purged theirs.
it is not sold at all, so how in the world can you get the installer on any pen drive, and XP installed from CD not pen..
worst of all XP installer, can not us 99% of all USB ports and then only half after the install (unless you force them via F6 and floppy drive with xp drivers on the floppy for THIS PC)
to use any relic PCs run LINUX> not XP
How to fix 1780 disk 0 failure
bad hdd.
- buy a new hdd.
- buy upgrade to SSD
- buy it in a PC store like Bestbuy
- buy it at ebay , amazon or 1000s of online stores (googled)
- the reload the OS.
- or have a shop fix your PC and avoid all this , work.
